What type of sandpaper for Powdercoatin my stock rims?
Old Feb 4, 2010 | 03:17 PM
SpeedDemon20's Avatar
SpeedDemon20
Default What type of sandpaper for Powdercoatin my stock rims?
what size do i need? is 80 ok?
Old Feb 4, 2010 | 04:36 PM
S30Love's Avatar
S30Love
80 seems pretty "low"
might leave deep marks...
I was thinking 200-600 area. grab a variety from 200-2000 (coarse to fine, and 2000 is really fine) experiment on some scrap metal or something of similar material and see how it works out. good luck
on my steelies, I just wire wheeled them, light sanded it, wiped it all down, adhesive promoter, and then just took my time to spray them. yes gold rattle can. but its a 14x6 steelie and im not driving a Z on 18" wheels
and remember, 90% prep, 10% paint.
Old Feb 4, 2010 | 05:42 PM
ZeezCustomz's Avatar
ZeezCustomz
If you don't want the powder coat to fall off, you have to media blast the entire wheel. Your powdercoater should know this...if he doesn't find another guy. Powdercoating is a very detailed process, if the prep ins't right, it won't hold up. If you don't know what media blasting is...it's basically sandblasting but not with sand, its done with small glass beads. Sandblasting is too harsh on alloy or aluminum and will create a surface that powdercoating will not adhere to. Hope this helps you out!
Old Feb 4, 2010 | 08:26 PM
Lee R's Avatar
Lee R
Bad prep work before powdercoating.....
Old Feb 4, 2010 | 08:45 PM
illest's Avatar
illest
80 is too rough.. I would say 120 then 320 to smooth them out and get 1000 & 2000 to finish them off.
Old Feb 5, 2010 | 01:21 AM
maXmood's Avatar
maXmood
Under Boost!
start @ 500, 800 then to 1000 and end it with 1200... u won't do much with 2000, so you better skip it.
Old Feb 5, 2010 | 01:46 AM
Z04's Avatar
Z04
best answer out of them all.
Old Feb 5, 2010 | 01:43 PM
ZeezCustomz
Thanks, I just hope he takes my advice..otherwise it will flake.
Old Feb 9, 2010 | 10:02 AM
skunk281's Avatar
skunk281
Yes media blasting is the only way to go.
Take the advice.
ablaine
Nov 29, 2016 10:13 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
