would this tire/wheel combo work good?
Old Mar 8, 2010 | 09:07 AM
whitecat's Avatar
whitecat
Default would this tire/wheel combo work good?
So I've spent the past few months researching wheels and tires of my 07 Z and I wanted to run it past you guys first to make sure I'm making a good decision.
Wheels - volk te37's 18/9.5 front and 18/10.5 rear with +22 offset on all four.
Tires - Nitto nt05's in 275/35/18 front and 275/40/18 rear.
reasoning for this setup - I like a square setup for handling so I wanted to keep the tire sizes as close as possible to each other. Now you may be wondering why I didn't pick the same size wheel all around, but this is because I want the lip in the back to keep the offset look. Also, according to nitto's website the tires fit a 9 to 11 inch rim so I'm in specification.
This all looks good on paper, but with little personal experience buying wheels and tires I don't want to be clueless on something.
thanks in advance
Old Mar 8, 2010 | 10:13 AM
duro78's Avatar
duro78
search through the wheel forum
Old Mar 8, 2010 | 11:06 AM
Brrcats's Avatar
Brrcats
I understand your preference for a square setup tire wise, but it just seems like such a waste to put a tire that small on a wheel that big. Although I'm a fan of big rubber in the back.
Have you calculated the tire difference for traction control purposes?
Old Mar 8, 2010 | 11:37 AM
Welcome. You give me little information to work with. TCS? VDC?
Old Mar 8, 2010 | 01:32 PM
scotts300's Avatar
scotts300
I what you're doing, here, though I agree that a 275 on a 10.5 will look a little stretched while the 275 on the 9.5 will look nice. Even if you could justify bumping the rear to 285, that would be helpful (though I'd rather see a 295 (or 305!) but am not sure it'll fit with the +22 offset).
Old Mar 8, 2010 | 02:44 PM
terrasmak's Avatar
Will work great and have no problems with TCS or VDC
Old Mar 8, 2010 | 03:40 PM
whitecat's Avatar
whitecat
I have, it's very close to the stock ratio so there would be no problems with TCS.
I have traction control but no VDC.
It seems like a staggered setup is the way to go (I'm not completely set on square so that's fine) what offset would you recommend?
Old Mar 8, 2010 | 05:45 PM
terrasmak's Avatar
Your offset of fine, and if you go stagger 295/35-18 would be a perfect match for your chosen front tires.
Old Mar 8, 2010 | 07:31 PM
27.5 mm is a consideravble difference;however, if this suits your needs I am 90 percent certain it is OK with TCS.
Dr.Paulyy
Jul 29, 2019 07:45 AM
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
Shane86
Sep 17, 2015 05:33 PM
