tire pressure monitor not working???
Old Oct 30, 2003 | 10:01 AM
tiggerpooh's Avatar
tiggerpooh
Default tire pressure monitor not working???
took of the stock 18s and put some 17s winters on...so the psi reading is not working anymore......anyone know how fix this???.......thanx
Old Oct 30, 2003 | 10:06 AM
350zluvr's Avatar
350zluvr
Put the stock 18s back on.
Old Oct 30, 2003 | 10:56 AM
teh215's Avatar
teh215
Did you transfer the TPS to the 17s?
Old Oct 30, 2003 | 02:21 PM
ChinaClipper's Avatar
ChinaClipper
Default Your choices
You can swap the Tire Pressure Sensors from your 18" wheels to your 17" winter wheels, or you can get a second set of TPSs and install them on your winter wheels. If you take the second option, then everytime you swap wheels, you need to go to your friendly Nissan dealer and have him "initialize" your car computer to 'recognize' the 'new' TPS codes. (I took the second option for my two sets of wheels with summer and winter rubber.)
Old Oct 30, 2003 | 02:40 PM
teh215's Avatar
teh215
Default Re: Your choices
Can 2 sets of 4 be initialized for 1 car?
Old Oct 30, 2003 | 02:41 PM
tiggerpooh's Avatar
tiggerpooh
so where r the seneors???.......i called nissan this afternoon and the guy told me that they r in the stock 18s?!?..is this true???......
ChinaClipper....so when i put my stock 18s back on in the summer...i have to go to the dealer and have them set it again??
thanx for the replys guys
Old Oct 30, 2003 | 07:14 PM
ChinaClipper
Default TPS info
so where are the seneors???.......i called nissan this afternoon and the guy told me that they r in the stock 18s?!?..is this true???......
The TPSs are standard equipment on Track, Touring and Performance model US-spec Zs. See the attached photo for what they look like uninstalled. You can recognize if your car has them or not by the metal-stemmed tire valve.
Yes,, whenever you change out tires (i.e. - sensors), the car computer must be reinitialized to recognize the new sensor coded signals. Each set of four sensors must be initialized whenever they are installed on the car - otherwise you get a display of just dashes.
Old Oct 31, 2003 | 03:29 PM
tiggerpooh's Avatar
tiggerpooh
Default Re: TPS info
thanx again man......so how much are a set of these tps??
Old Nov 1, 2003 | 07:42 AM
ChinaClipper
Default Re: TPS cost info
A set of TPSs (4) go for around $1200 from your friendly Nissan dealer
I got my set from a forum poster second hand for considerably less. Search and ask around.
HTH.
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
rizzla
Sep 29, 2015 03:58 PM
Shane86
Sep 17, 2015 05:33 PM
