Fitting 265/40R18 tires on 8.5" wheel
Old Apr 17, 2010 | 07:14 PM
cipric76's Avatar
cipric76
Default Fitting 265/40R18 tires on 8.5" wheel
Hello,
I was wondering if anybody tried fitting a 265/40R18 tire on the 8.5" wheel that come standard on the rear of the 07 touring. According to the tire specs it needs a 9" wheel but I heard people fitting tires on wheels 0.5" narrower than required by the tire.
The follow up question would be if you happen to know the disadvantages of doing this?
I am using my car for AutoX and I don't want to change rim sizes because it would take me out of the stock class but I want to add as much rubber as possible. With the current rims I can upsize(and be within tire requirements) by 20mm on the front but only 10mm on the rear.
Thank you very much,
Cipri
Old Apr 17, 2010 | 08:17 PM
I am always curious about upsize tire questions. Instead of a wider tire what about a better tire?
Old Apr 17, 2010 | 09:29 PM
T_K's Avatar
T_K
Originally Posted by cipric76
Hello,
Cipri
It's out of spec, but it's been done, and without much ill consequences. However, the end-user running a tire on an out-of-spec rim without any problems is far from any form of testing a manufacturer actually does. If you choose to do so, you may have to mess with tire pressures to get an ideal contact patch and in doing so there's no guarantee that tire pressure would/wouldn't begin to border being out of spec.
With all that being said; stock class in autocross is allowed any type of tire. That usually translates to drivers using the widest possible tire that the rim can be physically wrapped with and modifying the pressure to ensure a good contact patch. All in the name of reducing time and being competitive. On top of all that, they don't use street tires.
If your tires are for dual purpose, just get ones that fit properly. When you want to begin running competitively(in stock class), get some race rubbers and find an extra set of identical wheels in the FS forum. If you want to stay on street tires, the only street tire class for the Z (non-local) is STR, and has a 255 limit (which the Z is mostly non-competitive anyway).
Old Apr 17, 2010 | 09:38 PM
03threefiftyz's Avatar
03threefiftyz
265 is about max on an 8.5. I run a 275 rear and 265 front on 9" width wheel.
Old Apr 18, 2010 | 04:58 AM
cipric76's Avatar
cipric76
Thank you. I am indeed using the same tires for both street driving and AutoX. I wasn't aware of the 255mm limititation and I will have to read more about that.
Cipri
Old Apr 18, 2010 | 05:01 AM
cipric76's Avatar
cipric76
If by better you mean a race tire that is still not what I am considering. I run in street tire class thus researching which is the best tire is one part of the problem and beeing able to increase the contact patch is another part of it.
Thanks,
Cipri
Old Apr 18, 2010 | 05:02 AM
cipric76's Avatar
cipric76
9" - sigh. I need to see if I can have that but I'm not sure
Cipri
Old Apr 18, 2010 | 01:48 PM
T_K's Avatar
T_K
Thanks,
Cipri
What class are you running in?
Old Apr 18, 2010 | 03:06 PM
cipric76's Avatar
cipric76
I'm running in Street tire and for index I'm C stock(XCS)
Cipri
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
