Newb question - need help
Need help i just bought my car and ive had my eye on these wheels from when i had a 300zx.
its xxr 522 - and im not sure the size and all that of the 350z.. so help is great..
what will fit our cars
19x 8.5 ?
19x 10
19x 8.5 with 38 offset? will this fit?
19x 8.5 wil lthis fit with same offset?
5/100 lug patern or
5/120 lug patern
whats right and whats wrong lol? ty
19x 8.5 ?
19x 10
5/100 lug patern or
5/120 lug patern
i think there is a sticky that explains what works on the Z. maybe another member has the link. if i was going 19 i would do a 9.5 F and 10.5 R or on my set up i have 9F 10R. Fyi if your going for looks 19(ok performance, unless boosted) the way to go with out a drop really but you can make 18's(performance, even with boost if you got wide enough 18's) look great with a proper drop.
I hope i was clear, kinda tired for niosa!
How about a little homework including:
OEM wheel and tire specs
How to use a offset calculator
Study what other members have done
Then you can return and ask intelligent questions.
National Z Club President
if you can only afford 1200 wheels you cant afford FI...
our lug size is 114.3 soo no those wheels wont work.
19x9f 19x10r or 19x9.5f 19x10.5r with a offset of less then 30 the closer to 0 the better
19x 8.5 ?
19x 10
5/100 lug patern or
5/120 lug patern
19x 8.5 ?
19x 10
5/100 lug patern or
5/120 lug patern
For the rear we use a 10x18 38mm offset and use a 10mm spacer. I also suggest you replace all your wheel studs if you are going to do track days or race the car. I can give you additonal information if you email me at racerbob4@yahoo.com
