wheel weights (issue)
Old May 3, 2010 | 05:57 PM
350zx6r's Avatar
350zx6r
Exclamation wheel weights (issue)
I just got a new set of wheels, I took it to this nice shop, they put everything together but after the first trip I lost almost all the weights from both rear wheels. took it back in, they rebalanced, drove 300 miles straight and I lost some more..... wth? should I super glue them to the wheels? the car drives so nice after they balanced but it seems like they are not sticking well or something!!!
Old May 3, 2010 | 06:08 PM
Spike100's Avatar
Spike100
Did the tire shop offer any explanation?
--Spike
Old May 3, 2010 | 06:13 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Go to another shop
Old May 3, 2010 | 06:38 PM
350zx6r's Avatar
350zx6r
well I am about to go back tomorrow... and ask for at least part of the money back and go somewhere else. Because they mounted the TPMS sensors from OEM wheels, mounted and balanced tires w/o scratching anything. When I went back they said that it happens... and since this is my first aftermarket wheel IN A LONG TIME because this never happened with my 06 OEM wheels. now eventhough it is missing some of the weights the car still drives nicelly, sharp and no pulling or vibrations.
Old May 3, 2010 | 06:59 PM
Spike100's Avatar
Spike100
^^ Thanks for the reply.
If your tire shop successfully installed your TPMS sensors, mounted the tires on your new wheels, and mounted the wheels on your car; and did all this without scratching or damaging your wheels… they are likely a good shop.
It’s probably that the shop has encountered a new situation with your wheel/tire combination that defeats their usual attachment methods for wheel-balancing weights.
I would give the shop another chance. They will figure this out and find the correct method to attach the weights.
--Spike
Old May 3, 2010 | 07:11 PM
sdZ33's Avatar
sdZ33
Make sure that they use a cleaner to clean the surface where the wieghts are going... When I worked at discount tire, we used to scrape off the dirt and left over backing from the previous wieghts and then cleaned it with some stuff from a can... That should eliminate the chances for the wieght to fall off... GL
Old May 3, 2010 | 07:16 PM
Spike100's Avatar
Spike100
^^ Yes and of course, but these are new tires (no dirt/grime or previous weights).
--Spike
Old May 3, 2010 | 08:23 PM
Chebosto's Avatar
Chebosto
1. make sure the barrel is clean of ALL grease/brake dust/solvent
2. the adhesive they are using probably needs some bonding time, i'd probably put pressure / heat up/ whatever to get that adhesive to stick
3. if you don't care about the look, use foil tape to tape the weights down.
Old May 3, 2010 | 08:31 PM
350zx6r's Avatar
350zx6r
yup, these are brand new tires / wheels.
Old May 3, 2010 | 08:32 PM
350zx6r's Avatar
350zx6r
tape the weights down? for real? for how long?
thanks everyone for all the tips. Yeah I actually like the shop, I was actually advised to have them do it because they are known to be very good at it.
Old May 4, 2010 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
Wow, they must be using some cheap weights. I've had all my wheels balanced with stick on weights for years and have never had one come off. In fact, the biggest problem is getting the old ones off to balance it later after a tire replacement.
I still have the tape on some wheels where they took the weight off and couldn't get the tape off.
Old May 4, 2010 | 08:18 AM
Chebosto's Avatar
Chebosto
brake cleaner and/or wd40 on the adhesive tape worked for me. just have to pick at it.
Old May 4, 2010 | 08:50 AM
terrasmak's Avatar
Do what bike racers do, speed tape over the weights. You may even be able to get the right color to match the wheel
Old May 4, 2010 | 09:16 AM
DavesZ#3's Avatar
DavesZ#3
I've tried WD40, mineral spirits, Goo Gone and just about anything else that won't harm the finish.
A putty knife does some good but still mars the paint.
Old May 4, 2010 | 02:09 PM
Spike100's Avatar
Spike100
My experience with wheel weights matches Dave’s comment. The usual problem is removing the tape/adhesive, and not the weight flying-off the wheel.
Reading 350zx6r’s information, it sounds as though the tire shop is competent. I’m sure they are frustrated, but they will figure this out.
The problem must be with the wheel’s surface and/or a coating on the wheel. My guess (this is a guess ) is that the shop will need to scuff/ polish the wheel’s surface where the weight is applied to assure adhesion.
Question: What brand wheel is this?
--Spike
Old May 4, 2010 | 03:11 PM
350zx6r's Avatar
350zx6r
I got the FIVE AXIS
https://my350z.com/forum/wheels-and-...me-wheels.html
right here on this forum
Old May 4, 2010 | 05:04 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by 350zx6r
I got the FIVE AXIS
My buddy has this EXACT same wheel, no problem with the wheel weights sticking.
One of his wheels did come from the factory out of line, though.
Old May 4, 2010 | 05:40 PM
Spike100's Avatar
Spike100
I suppose that storing the weights and the adhesive in an area that was too cold or too hot (outside manufacturer’s specifications) could possibly affect adhesion. I doubt that the adhesive would be past its expiration date in a busy tire shop.
It’s probably some sort of surface layer (resin, wax, or petroleum-based product) the manufacturer applies to the wheel for protection and rust-prevention that’s defeating adhesion of the wheel weights.
The shop needs to insure a good adhesion surface on the wheel.
--Spike
350z82
Oct 1, 2015 06:25 PM
