Need Help: 19x9.5+12(245/35) 19x10.5+12(275/35)
Old May 13, 2010 | 04:29 AM
PikeZ_350's Avatar
PikeZ_350
Default Need Help: 19x9.5+12(245/35) 19x10.5+12(275/35)
I'm getting new wheels on Friday, and I have a couple questions.
They will be 19x9.5 & 19x10.5 +12 all the way around on 245/35F 275/35R.
Will this setup have any stretch at all? I've researched and also been told by several friends that it will have a slight stretch, nothing crazy. That's what I'm going for...Flush with a slight stretch.
Any advice/suggestions will be very helpful!!! THANKS.
Old May 13, 2010 | 05:52 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Your friends told you right, slight stretch.
Old May 13, 2010 | 06:13 AM
vex008's Avatar
vex008
check rimtuck.com
plug in the specs and see what pops up
Old May 13, 2010 | 06:21 AM
Checkmate58's Avatar
Checkmate58
Setup should look fine and yes, slight stretch. The 245 will look more stretched then the rear though.
Old May 13, 2010 | 06:23 AM
vex008's Avatar
vex008
Default thought i'd help a little more...
these two popped up in there, different brands would probably yeild different result but in the same ballpark i guess - you get the idea.
Link:
http://www.rimtuck.com/thumbnails.ph...&sidewallr=35&
Old May 13, 2010 | 08:31 AM
SuperBlack350z's Avatar
SuperBlack350z
depends on the tires you get. You can get certain model tires and it will be fat and buldgy with those sizes.
Old May 13, 2010 | 08:48 AM
trueskillz12's Avatar
trueskillz12
here are mine
toyo t1r 255/35 & 275/35
Old May 13, 2010 | 08:58 AM
zerostyle's Avatar
zerostyle
stay with those sizes...245/275 are common sizes. which means cheaper tires. trust me.
Old May 13, 2010 | 09:02 AM
SuperBlack350z
Jordan, i hope you didn't spend your hard earned cash those cheap te37 volk knock offs.
Old May 13, 2010 | 09:03 AM
SkullZ's Avatar
SkullZ
I have this tire setup, though my rears are 11" rims. Front will be slightly more stretched for you.
Don't have any good comparisons of the fronts, but here are 275's on a 11 inch rear.
Old May 13, 2010 | 10:25 AM
lgear080's Avatar
lgear080
Sound advice... just buy my reals!!!
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
fairladyZ in Japan
Jul 15, 2004 09:28 PM
meatwad79
May 19, 2004 04:52 PM
Bassmaster
Feb 4, 2004 05:48 AM
john350Z
Mar 8, 2003 10:23 PM
