Offsets thread?
Old May 17, 2010 | 05:32 AM
digitaltrance's Avatar
digitaltrance
Default Offsets thread?
Is there a therad with optimal offsets and tire combos?? I am trying to get some new rims, but I want the best flush look without doing the streched tires/rims sticking out, look. Since I it will be a daily driver and I can't afford tires every 3months.
Thanks guys!
Old May 17, 2010 | 06:03 AM
GeauxLadyZ's Avatar
GeauxLadyZ
9.5 front, 10.5 rear, et.22 all around, 255/35/19 front, 285/35/19 rear. (or)
9.5 front, 10.5 rear, et.17 front 245/35/19, et.18 rear 275/35/19
Both will require rear fender roll if drop is aggressive.
Your welcome.
Old May 17, 2010 | 06:29 AM
diablox1's Avatar
diablox1
yes.
Old May 17, 2010 | 06:55 AM
R3belzBRN's Avatar
R3belzBRN
Originally Posted by diablox1
yes.
and its alot! all over the forum.. just search for it.
Old May 17, 2010 | 09:56 AM
digitaltrance
Thanks, I did search, but these forum search results are alll over the place. I will try again.
Thanks again!
Old May 17, 2010 | 10:12 AM
You have been a member for 3 years and do not use an offset calculator?
Old May 17, 2010 | 01:00 PM
3m wol8's Avatar
3m wol8
lost art lol plus that's work.. you have to type the info in and go measure.. it's MUCH easier when someone tells you what will work with your car and how low it sits and your camber.. ya know?
Old May 17, 2010 | 08:22 PM
digitaltrance
I haven't had Z since mid 2009. Sorry I am just now getting into the 350Z mod scene. I don't mind doing work and research, hence the low post count, read a lot more than I post.
Thanks for the tip though...
Old May 17, 2010 | 08:35 PM
ComeBack's Avatar
ComeBack
The width of the wheel and how low you are will come into play as well. Are you on springs or coils? also what size wheels are you looking for? 18's and widths that you would want? 19's and widths that you would want? Do you want staggered or a square setup?
Old May 17, 2010 | 08:46 PM
Max-G's Avatar
Max-G
more info is needed for an adequate response. aka. stretched or max rubber? lowered or stock height? adjustable arms or no? check this site out to get an idea of sizes + offsets that work well http://www.rimtuck.com/search.php
Tochigi_236
Sep 27, 2015 03:40 PM
