Up Sizeing 17s
Old May 23, 2010 | 05:50 PM
zJames's Avatar
zJames
Default Up Sizeing 17s
whats the most i can up size tires on my 17in stock wheels?
Old May 23, 2010 | 06:19 PM
sdZ33's Avatar
sdZ33
I think you can fit a 265 on the rear
Old May 23, 2010 | 06:29 PM
midz350's Avatar
midz350
20'' tiers would look sick on 17'' wheels
J/K how wide are the rears?
Old May 23, 2010 | 07:23 PM
zJames's Avatar
zJames
265? and i believe the rears are 245. thanks
Old May 23, 2010 | 07:34 PM
Don't. Get better tires instead of wider tires.
Old May 23, 2010 | 08:38 PM
CORNELL's Avatar
CORNELL
^wow he was nice and gave you good advice
Old May 23, 2010 | 11:07 PM
R3belzBRN's Avatar
R3belzBRN
someone is in a good mood today. hehe
Old May 24, 2010 | 12:09 AM
Mike@Blackline's Avatar
Mike@Blackline
nah all of davidv's replies for over a month have been nice. maybe the mods threatened teh ban hamma on him
Old May 24, 2010 | 12:26 AM
terrasmak's Avatar
8 inch wheel in the rear, 7.5 inch front. Get wider wheels is your best upsize.
Old May 24, 2010 | 12:46 AM
adamc's Avatar
adamc
i have 275/45/18's on the *** of my Z
Old May 24, 2010 | 10:47 AM
zJames's Avatar
zJames
yea im gonna go what david said, or get wider wheels. which ever is in the budget
Old May 24, 2010 | 06:56 PM
Spike100's Avatar
Spike100
zJames has 17" wheels. You have 18" wheels, so the size you mention won't work at all.
--Spike
Old May 24, 2010 | 07:43 PM
adamc's Avatar
adamc
yea i read it wrong... my bads *fail*
Old May 24, 2010 | 07:52 PM
Spike100's Avatar
Spike100
You have the stock 17” Aluminum Alloy wheels so…
  • Front Size: 17x7.5, Offset: +30mm, Weight: 23.26lbs, Tire: 225/50/17
  • Rear Size: 17x8.0, Offset: +33mm, Weight: 24.14lbs, Tire: 235/50/17
The good things that 17” wheels/tires provide are:
  • A more comfortable ride
  • Tires for 17” wheels generally cost less than tires for larger wheels (i.e., 18”, 19”, or 20”)
  • Lighter wheels (all being the same, meaning the alloy used in the wheel)
For street use: For an upgrade to a wider tire on these stock 17” wheels, you could mount:
  • Front: 225/50-17"
  • Rear: 245/50-17”
For the track, the “rules” don’t apply, and you go with whatever works best for your goal. You would probably go a lot wider.
--Spike
Old May 24, 2010 | 08:08 PM
ITOzann's Avatar
ITOzann
get some high quality tires in the 255/265 set up
sales@czp
Sep 23, 2019 03:30 PM
