XXR Wheels Thread
Old Oct 22, 2011 | 02:29 PM
  #461
hunterclowdus's Avatar
hunterclowdus
Originally Posted by BSERIEuS
i think that you're going to need some tuner/spline lugs. same ones you see at your local autozone.
the lug nut holes look kind of slim and from my experience with xxr wheels on my GF's car...the muteki open ended lugs were too fat for the hole.
and blue lugs look okay. if you have nothing else to flow with the blue lugs...they can stand out...and might look wack. i prefer black lugs.
thanks for the input man I am going black and keeping it clean. can anyone who have 18x10.5 xxr 526 post pics please thanks
Old Oct 22, 2011 | 07:53 PM
  #462
KTran's Avatar
KTran
morning,
noon,
like BSERIEuS said, use tuner/spline lugs
im personally using muteki lugs open ends with mine, should be similiar to slim spline or gorilla style lugs.
Old Oct 22, 2011 | 08:50 PM
  #463
kemps's Avatar
kemps
KTran are you running the same size tires and offset as you were in the last set of pics? Those tires look newer. Will be doing 18x10.5 on all four corners pretty soon as drift spares. More pics!
Old Oct 22, 2011 | 11:42 PM
  #464
KTran's Avatar
KTran
they're same spacer setup, same wheels but up front is a different pair and you're right, the front tires are new, 245/40/18 on 10.5 width.
i caught 2 blowouts on my other tires/wheels, shetty old 235/45/18s(my fault).
Old Oct 23, 2011 | 05:36 AM
  #465
Maxx87's Avatar
Maxx87
Nice setup KTran, how are the wheels holding up? Many say they're cheap are will bend at nothing even if they didn't own any. I thought about the 526 because in my area they're much easier to get in case one bends compared to volk, work, etc.
Old Oct 23, 2011 | 07:42 AM
  #466
SniperHunter's Avatar
SniperHunter
I had XXRs on my 350Z. They went through some of NYC's most beautiful bumps and potholes without an issue. And they were lightweight - 22lbs each. I had the XXR 518s in 18x8.5 all around.
Old Oct 23, 2011 | 01:14 PM
  #467
Maxx87's Avatar
Maxx87
Thanks for the post Arnold. I live in the province of Quebec in Canada and we are popular for having some of the worst roads (or simply the worst) in North America. I thought about the 20's and getting a N2 front with Ings sides and rear. I think i'll get them painted silver or hyperblack. Can't wait to get all the parts this winter
Old Oct 23, 2011 | 08:31 PM
  #468
BYBYCOP's Avatar
BYBYCOP
For anyone who buys XXR 522's for the Z, they take a hub centric size of:
66.1 inner
73.1 outer
I bought them from NLMotoring, they were very helpful. I paid $3.99 a piece, so $16.00 total. It definitely helped with the vibration in the steering wheel. If you have questions, you can PM me. Love my XXR's though, great rims.
Old Oct 24, 2011 | 04:20 PM
  #469
hunterclowdus
Will 265/40 square set up work with 18x10.5 +20? I want a square set up so I can rotate my tires. I plan on using a 15mm spacer in the rear just to help with the slightly poke look. I just don't want to rub up front. I am dropped on Hotchkis. Thanks for the input I really appreciate it
Old Oct 24, 2011 | 07:18 PM
  #470
theianmcdougall's Avatar
theianmcdougall
yes that would work, i have 18x11+1 up front with a 255, so i assume that will work fine
Old Oct 24, 2011 | 08:37 PM
  #471
hunterclowdus
alright sweet thanks for the feedback
Old Oct 25, 2011 | 01:21 PM
  #472
RyebreadZ's Avatar
RyebreadZ
Do your fronts rub? I was thinking about getting these and using a 20mm space up front.
Old Oct 26, 2011 | 07:24 PM
  #473
Bmurray350z's Avatar
Bmurray350z
im a big wheel noob.. anyways im looking at getting 521's now.. not varrstoens. they've grown on me.
i wanna go
F 18x8.5 +25 (add 15 mm spacers)
R 18x10 +25 (add 15 mm spacers)
1. will this sit flush?
2. would you recommend diff size spacers?
3. would i need a roll and/or pull since spacers are being added?
thanks, also im lowered on gf210's (1.0"/1.2")
Old Oct 26, 2011 | 08:58 PM
  #474
hunterclowdus
stupid question but bear with me... If I run a square set up 265/40 with 18x10.5 +20 wheels, can I run a 20 mm spacer in the rear without rubbing or would I have to roll my fenders? Also would that be equivalent to having a 285 rear tire? Thanks guys
Old Oct 27, 2011 | 04:55 AM
  #475
BSERIEuS's Avatar
BSERIEuS
from what i've gathered through the years, i've seen people run 265/35 all around. even 275/35 and 285/35.
why the 40 series sidewall?
anyways, if you go that route, the only way it will rub is if you're super super low.
not sure if you mentioned what your suspension set up is...but if its just on springs...i doubt it will rub. you'll eventually want to go lower....so you might as well roll those fenders! better safe than sorry....AMIRITE?
Old Oct 27, 2011 | 11:23 AM
  #476
hunterclowdus
haha yes you are. but the 40 profile is to fill the fender gap. I am dropped on Hotchkis which is not very low, so to get as flush as possible I need the 40 instead of the 35.
Old Oct 27, 2011 | 11:45 AM
  #477
Bmurray350z
would the 521's
F 18x8.5 +25
R 18x10 +25
225/45/18
245/45/18
with 15mm spacers all around sit flush? would any roll be required you think?
thinking about getting them in the gunmetal.. they're growing on me.
Old Oct 27, 2011 | 01:13 PM
  #478
theianmcdougall
^ dont do 8.5
get 18x10 all around
20mm spacer front 30mm rear
235/40 front
245/40 rear
no rolling required, maybe a little if you slam the rear.
Old Oct 27, 2011 | 01:16 PM
  #479
Bmurray350z
^ dont do 8.5
235/40 front
245/40 rear
i've thought about that but i like having staggered wheels. but i mean idk yet. what are the pros and cons of doing a square setup? btw im lowered on tanabe springs. so only about a 1" drop fr/rear.
Old Oct 27, 2011 | 06:10 PM
  #480
theianmcdougall
pro's: you can rotate them
con's: none, 8.5 rims are useless if you plan on stretching tires on a z
trust me, just get 18x10 all around, you will be pleased
