XXR Wheels Thread
Old Jul 19, 2013 | 07:42 PM
  #1581
pagoda240's Avatar
pagoda240
Xxr530 18/9.75 Et 20 / 2003 touring / stock height
overall I like them but need to paint door handles black and maybe a spacer in back.
Old Jul 19, 2013 | 08:20 PM
  #1582
taryon's Avatar
taryon
^ Looks good man. Spacers in the back will also make it look better
Old Jul 20, 2013 | 02:57 AM
  #1583
pagoda240's Avatar
pagoda240
I am thinking the same thing...
Old Jul 23, 2013 | 07:52 PM
  #1584
Changtownriot's Avatar
Changtownriot
Hey man did you have to roll your fenders with the 18x10.5???
Old Jul 25, 2013 | 10:28 AM
  #1585
.:T3RBO:.'s Avatar
.:T3RBO:.
Originally Posted by OneLovelyZee
Thanks for the info, man. I'll just go browse on Google to see what it looks like on other cars.
I'm ordering mine this weekend. I emailed NLMotoring and they said they are on backorder and should take 3-5 weeks. But am look other places mentioned above now. I have the pearl white I was thinkin of going with platinum 18x11 and 18x9.5. Shall look sick. I'll post pics when they be on the Z.
Old Jul 25, 2013 | 06:28 PM
  #1586
Roadrage68's Avatar
Roadrage68
Question
Been lurking here for a few weeks now. Read this thread twice, and the Varrstoen thread once.
And here is what I'm thinking:
XXR 521 Silver Machined
18x10 +12 (x4)
265/35/18 (x4)
I have a black 2003 Base Z.
I bought it fairly cheap and don't want to put a whole lot of money into it due to the fact I may sell it at a profit for a newer lower mileage Z.
I only want to lower it with springs, and I realize I may have to roll the rear fenders.
I may even get some spacers to get the right look.
What do you guys think? And what springs do you think I will need?
Thanks in advance.
Old Jul 25, 2013 | 06:41 PM
  #1587
freddys 350z's Avatar
freddys 350z
265-35 are too small for the rear. not gonna look right and its gonna mess with the whole abs/wheel speed sensors.
Old Jul 25, 2013 | 06:52 PM
  #1588
Roadrage68's Avatar
Roadrage68
Well I thought the idea of a square setup is to be rotatable and you can't do that running 2 different sizes on the same size wheel.
Can someone explain how it will affect abs/speed sensor?
I understand the speedo will be off.
Old Jul 25, 2013 | 08:14 PM
  #1589
freddys 350z
either way you go through tires at the same rate. fronts last so long its ridiculous. i think they will get dry rot before i use up all the tread.( using bridgestone re760). id figure 3 sets of rears for every set of fronts.
so, imo its not worth throwing off your speed and having the rear tires look to skinny.
Old Jul 25, 2013 | 10:27 PM
  #1590
Roadrage68's Avatar
Roadrage68
My concern with different sized tires between front and rear on same size rim is that the sidewall height will be different and possibly the stretch/aspect ration of tires will be different. This doesn't look funny or bother anyone.
Chime in if you are running this setup.
Old Jul 25, 2013 | 10:46 PM
  #1591
freddys 350z
well, the rear is supposed to have a bigger side wall then the front...look at any rear wheel drive car. nsx, corvette, 370z, m3. if anything, having a skinny tire in the rear look funny.
Old Jul 26, 2013 | 10:28 AM
  #1592
SamPappas's Avatar
SamPappas
18x10 +12 (x4)
265/35/18 (x4)
Thanks in advance.
I had those wheel specs only the fronts were 245's. xxr's cheap asses makes it so that you can't put 20mm spacers on the wheels cause they don't have the "gaps" in the back of the wheels that are necessary so get the +25 offset wheels and get 25mm spacers. Trust me you will thank me later.
also to anyone who looked at my car with the gold xxr's and liked it, it had bigger sidewalls in the front and no one ever said anything negative about it.
Old Jul 26, 2013 | 04:44 PM
  #1593
freddys 350z
i did...(really, i did)
if you wanna run spacers, put longer studs and some z1 slip on spacers. i dont like the bolt on type.
Old Jul 27, 2013 | 11:28 AM
  #1594
Roadrage68's Avatar
Roadrage68
How big of spacers can you slip on with stock lugnuts?
How do you guys think a black Z would look with 18x10 +12 square in flat black?
Old Jul 27, 2013 | 11:31 AM
  #1595
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Like a black Z with flat black wheels
Old Jul 27, 2013 | 04:03 PM
  #1596
freddys 350z
How big of spacers can you slip on with stock studs?
12x1.25 pitch..they say after you screw it down the same distance as the diameter, that is all you need. so the min turns of the lug to have full strength is 9.6 turns of the lug nut, or 12mm. so now you need to know the thickness of the wheel where the lug sits against and the length of the stud and you have your answer on how big of a spacer you can run. (if you have aluminum lugs, dont run spacers on stock studs. )
or you can just run a 5mm spacer....
Old Jul 28, 2013 | 05:08 AM
  #1597
LandonZ's Avatar
LandonZ
im looking into the 18x8.75 and 18x9.75. They are +20 offset, I have 235-45-18 front tires and 245-45-18 rear tires. With the +20 offset, what should I expect? Will that fit well? will they stick out real bad?
Old Jul 31, 2013 | 06:38 AM
  #1598
michaelmoon912's Avatar
michaelmoon912
265/35/18 all around doesnt look bad.
cant comment on vdc issues, i has teh base model.
to give you some perspective, my car is on 18x10.5 +20 on all four.
an 8.75 +20 on the front would be 22 mm less to the outer edge, a 9.75 +20 on the back would be 10mm less to the outside edge. It wouldnt look too bad. Dont know about the tires sizes though, im having a hard time imagining what a 45 series would look like in my head lol.
Attached Thumbnails XXR Wheels Thread-971821_4696018528559_1975834656_n-1-.jpg
Old Jul 31, 2013 | 07:01 AM
  #1599
pagoda240's Avatar
pagoda240
18x9.75 with 20et & 235-45-18 / square - above , but i want to got with 265/35/18's in rear and maybe a 15mm spacer.
Old Jul 31, 2013 | 07:10 AM
  #1600
michaelmoon912
265/35's rear would look perfect on that wheel along with a 15 mil spacer.
Fronts look good.
