XXR Wheels Thread
found some used tires around the shop, figure i throw them on for ***** n pics.
20x11 on the left, 18x10.5 on the right
F: 18x10.5 +20 235/40/18,
on car in pics, w/20mm spacer=18x10.5 +0
R: 20x11 +15 245/40/20,
on car in pics, w/25mm spacer=20x11 -10
enjoy!
ps. these arent my permanent wheels, just drift wheels i threw on for pics to show ya'll.
enjoy!
Is that how they fit with coils? How low is your drop?
What are your guys thought on these wheels for my Z?
XXR 531 18x11 +20 Square setup. They also make a 18x9.5 +20 but I dont think they would look as aggressive. Not sure on tire size either a 35 or 30 series.
Please don't lecture me on wheel cheapness. I don't plan on keeping this car for a long time and want to buy some inexpensive aggressive wheels.
BTW I have a Black 2003 Base 350Z.
It will require a 5mm spacer up front to clear the knuckle. It will be very aggressive , a 10mm rear spacer will be wanted out back because of the needed front spacer. 275/35's all around should fit fine.
http://www.z1motorsports.com/350_g35...oducts_id=4215 awesome spacers.
http://www.corsportusa.com/store/cat...FQnhQgodaFQAwg for lugs, they will complete the look for the wheels.
I might be at SEMA, hopefully I can spend one day at the show.
Hey guys I just ordered some 18x8.75 530s, I was wondering if you guys kept the oem lugs or had to buy new ones. If indeed you had to buy new ones do any of the tuner lugs work? I feel like the xxr's have a smaller lug well and the oem lugs are pretty fat.
Oem lug nuts will not work, you'll need aftermarket "tuner" lug nuts as you mentioned. Muteki makes some pretty reasonable and durable lug nuts.
Hey guys, I bought XXR 521s 18x10 +12. I like them but they look goofy at stock height (much more so than my Rota torques [fs cheap btw]).
-Right now Im debating between which coils to get, Megan (heard bad things but cheap), Topspeed Pro-1(cheap but havent heard anything bad yet), Stance SS, or BC BR. I daily my car, no track, and Id like to get rid of wheel gap so about a 2" drop.
- I understand Ill need rear camber arms and toe bolts, but will I need the front camber arms?
- Which of those coils do you guys recommend?
Hopefully someone can help me out
Thanks a lot in advance!
. Yea i need to fix the front mesh still, get the dent out of my hatch, fix a dent in my roof, fix small dings on my passenger door, and detail the engine bay still. One thing at a time though.
