WTF? My tire blew today
Old Jun 14, 2010 | 07:07 PM
biznut's Avatar
biznut
Default WTF? My tire blew today
So I was driving back home, and I heard this loud hissing noise. I looked and saw my tire was deflating! I put some air in with a portable air compressor and tried driving to the nearest discount tire. The tire had a bubble in it! About half way to discount I heard the loud popping sound and my tire blew. Any idea why this happened?
Old Jun 14, 2010 | 07:33 PM
Black Z Eddie's Avatar
Black Z Eddie
In a nutshell:
Low tire pressure ---> Generates more Heat ---> Tire kaboom.
Old Jun 14, 2010 | 07:51 PM
Waiz's Avatar
Waiz
How old was this tire?
Old Jun 14, 2010 | 08:09 PM
biznut's Avatar
biznut
No clue. Just got the car last week. Treads were very deep, and still had the colored dots they usually put on new tires. Vehicle has 46,000 miles.
Old Jun 14, 2010 | 09:36 PM
zerostyle's Avatar
zerostyle
bubble could be manufacturer defect...either that or you hit a pot hole or a bump or something. the impact can cause a bubble...
p.s. next time your air is hissing stop, put your spare on...that was dumb of you to fill it up and drive on it. things coulda been much much worse
Old Jun 14, 2010 | 10:06 PM
dhays's Avatar
dhays
Pretty unusual to have a manufacturing defect, but it happens. Likely the PO had just not maintained the tires properly.
Old Jun 15, 2010 | 03:19 AM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by Black Z Eddie
In a nutshell:
+1 Underinflation is the most common cause of tire failure. Since you just got the car and don't know its history, I'd advise you to get it inspected to make sure there are no other surprises lurking. If the previous owner had one tire underinflated, then chances are all of them were.
Old Jun 15, 2010 | 03:25 AM
In a nutshell:
Correct. The additional pressure will find the weakest place in the tire to escape.
Old Jun 15, 2010 | 09:38 AM
biznut's Avatar
biznut
Thanks!
Old Jun 15, 2010 | 10:19 AM
Black Z Eddie
Since the tire appeared new, some of the causes of the hissing leading to underinflation:
1] bad tire (though, nowadays, it's unlikely like mentioned somewhere above)
2] bad mounting
3] bad valve stem or installation of valve stem
4] ran over something
5] vengeful ex
I had a similar thing happen with the popping sound couple years back. I was on the freeway and heard a couple of pops then the TPMS came on. I quickly pulled over and changed to my spare. Luckily, the tire didn't explode.
Old Jun 15, 2010 | 12:19 PM
scotts300's Avatar
scotts300
In addition to the possibility of having hit a pot hole to cause a bubble, I've seen bubbles form after tires were dismounted and remounted from strain caused on the machine.
Old Jun 16, 2010 | 06:42 AM
biznut's Avatar
biznut
I did remount after changing the breaks, but I've never had the problem of tires bubbling. This is my third car, and I have never have this happen to me
Old Jun 16, 2010 | 09:57 AM
scotts300's Avatar
scotts300
I dismount/flip/remount a lot of tires, too, and it's only happened once. It's still possible. When you get the tire discounted, see if you can see any stress in the tire in the area that the bubble formed.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
