offset of factory wheels and aftermarket wheels
Old Nov 7, 2003 | 04:58 PM
backagain's Avatar
backagain
Default offset of factory wheels and aftermarket wheels
can someone please explain offset to me, i just got my HP EVO's in and it's 38 offset, good/bad, i really have no idea, what is the stock wheels offset, thanks in advance.
here are my new wheels,
Old Nov 8, 2003 | 02:44 AM
03 Z for ME's Avatar
03 Z for ME
Stock offsets are 30... (on the Performance 18 x 8's)
Old Nov 8, 2003 | 07:03 AM
lowrider's Avatar
lowrider
I'm no expert on offsets, but yes the stock offsets for the 18 x 8 wheel on both the "Z" and the "G" is 30mm. I have a set of Nismo 18s 8.5" front and 9.5" rear. the offsets are 25mm front and 30mm rear. The 25mm front coupled with the .5" wider width means that the front wheel edge sits out about .5" further than before (1/2 the .5" width increase plus the added 5mm offset). The rear sits out about .75" further than before (1/2 the added width of 1.5" with no added offset) Personally I would not want them out any further, but that's just my opinion.
I don't know the widths of your wheels, so I really can't comment on your situation, except to say the offset is 8mm more than stock. Which means that if the widths were identical to stock the edge of the wheel would sit further in by between .25 to .5". Positive offset means the wheel edge sits further in.
This is confusing because of the positive/negative thing and because wheels and tires are the only components measured in both the common inches/feet measurement system and the metric system. The wheel diameter of wheels and tires is inches, the width of a tire is metric. The diameter of a wheel is inches, the width is inches, but the offset is metric.
Lou
Old Nov 8, 2003 | 04:06 PM
backagain's Avatar
backagain
gotcha, (i think) ,but yea, they are a lot wider, the new ones are 9 wide in rear, and the stock is, 7 i believe, not really sure how wide stock wheels are,
Old Nov 8, 2003 | 06:41 PM
lowrider's Avatar
lowrider
As said above the stock 18s are 8" wide at all four corners. The 17s are 7.5" front and 8" rear. No "Z" wheel is 7" wide. What do you mean by "gotcha?"
You asked a question, I'm trying to help.
Lou
Old Nov 8, 2003 | 07:51 PM
backagain's Avatar
backagain
oops, didn't re-read it, thanks for the help though, now i see, i mis-read it, my new wheels are 18x8 front, and 18x9 rear, just wondering how far in/ far out the wheels will sit from the stock wheels,
ray
Old Nov 9, 2003 | 05:03 AM
kbomb's Avatar
kbomb
Can u post pics when installed. These are not bad wheels for the price. Did u get silver or gunmetal?
I think offsets are 29mm. I have ADR M-sports with 35 mm offset and the wheel is slightly tucked behind the rear fender. The lower the number the more flushed out to the fender it is. I think this is rite? U might have to use spacers to get the rear wheels to come out more...
try asking Todd from Discount Direct...hes got a thread on all of this.
Old Nov 9, 2003 | 05:31 AM
backagain's Avatar
backagain
i have the hypersilver DARK, but they aren't DARK DARK, just a litte darker than the silverstone z. i think the color is perfect, pm me if you are interested in a set. thanks
ray
Old Nov 10, 2003 | 11:07 AM
srmd22's Avatar
srmd22
by gotcha, he meant "I see what you are saying," not "haha, caught you being foolinsh"
Old Nov 13, 2003 | 10:53 PM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
so the higher the offset, the further the wheels stick out?
Bat™
Old Nov 14, 2003 | 06:34 AM
EL PAALO's Avatar
EL PAALO
Bat™
opposite
+40 is closer to engine than +30. +30 is closer to fender than +40.
Old Nov 14, 2003 | 06:39 AM
EL PAALO's Avatar
EL PAALO
Hopefully, I'm not hurting anyone's feelings here, but this is one of the best car specific wheel/tire FAQ's around -
http://350zmotoring.com/forums/Wheels_and_Tire.php
Old Nov 14, 2003 | 12:25 PM
Blue Batmobile
Inventor
Blue Batmobile
Cool, thanks for the info guys.
Bat™
sales@czp
Sep 23, 2019 03:30 PM
