Volk TE37 Thread
Old Nov 16, 2015 | 05:35 PM
  #1421
isy_nismo's Avatar
isy_nismo
Originally Posted by turboed350z
With the 10.5+15 youll be getting the face 2. Which is slight concave. Its in the middle of extreme concave and flat face. Its also the best looking really.
According the rays info 10.5 +15 is Face 1, 10.5 + 0 will be Face 2...... I'm wonder if 10.5 -40 will fit and if it will be aggressive enough??
Old Nov 16, 2015 | 05:58 PM
  #1422
turboed350z's Avatar
turboed350z
I stand corrected youre correct. As for 10.5-40 that is going to need a wide body kit to fit.
Old Nov 16, 2015 | 07:55 PM
  #1423
isy_nismo's Avatar
isy_nismo
What about the 10.5 +0...or 10.5 -25 all around?
Old Nov 17, 2015 | 08:32 PM
  #1424
isy_nismo's Avatar
isy_nismo
UP with more info please!!
Old Nov 18, 2015 | 04:36 AM
  #1425
turboed350z
10.5+0 is going to be agressive and will likely need anfender roll. The 10.5+15 will be more flushed. the 10.5-25 is going to poke out unless you run retarded amount of camber.
Old Nov 18, 2015 | 02:12 PM
  #1426
isy_nismo's Avatar
isy_nismo
Thanks for info....will see then, maybe I will wait till somebody get a set for the 350z....I will like -25 due to more lip and more concave pokes, I will run some camber up to the front and rear but I will wait till somebody tested firs haha
Old Nov 18, 2015 | 04:16 PM
  #1427
WPPJR30's Avatar
WPPJR30
I do not believe I have posted my TE37's in this thread…
First set… 19" Custom Order Mercury Silver - (I later changed the decals to blue.)
Second set… 19" TE37SL
Third set… 18" TE37 Large PCD (for my current daily w/ a 5th spare )
Fourth set… 18" TE37SL (for my current Z)
(Unfortunately, I do not have any pictures of my two current sets mounted, as I have yet to purchase rubber for either vehicle.)
Old Dec 7, 2015 | 10:48 AM
  #1428
Depravity's Avatar
Depravity
Hey everyone,
I recently acquired a set of TE37s, and I had a quick question for you guys. Please bear with me, I've been researching but I haven't found a solid answer yet. Basically I'm looking to add a new set of TPMS sensors to these because the previous owner never had it done. Do I need a bracket/adapter if I'm using a Volk valve stem?
When I had my Volk GT-S wheels, I used this and it was perfect. From what I understand (based off the reading I've done) - With the TE37s, I don't believe I need anything, it should be TPMS-compatible already. HOWEVER, I don't want to use my OEM valve stem so I think I need to look for a bracket/adapter for my blue Volk one?
Old Dec 7, 2015 | 11:37 AM
  #1429
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
The GT-S valve stem is entirely different than the TE's. I do not believe you can incorporate those bracket adapters to the TE valve stem like you did for the GT-S's. To answer your question, the stock TPMS's will mount onto the one piece mono block TE's without needing any brackets. I tried this before and decided to go with the Volk's blue valve stem versus the OEM TPMS because the blue valve stem looks so purty.
IMO - it boils down to functionality/ugly valve stem with OEM or pretty valve stem/no functionality with Volk.
GL
Old Dec 7, 2015 | 11:48 AM
  #1430
Depravity's Avatar
Depravity
GL
Gahhh, that was the bad news I was hoping to NOT hear lol. It's just so damn sexy that I can't part ways with it
I'll call up the shop who put those bracket adapters on my GT-S wheels and see if they'd think it would also work with the TE37s. Coincidentally, they're a Volk Distributor so maybe they'll know of a solution. I know banding the sensors onto the wheels is sort of frowned upon, but it's looking like that might be the only option left if I want to keep using the purrrty blue Volk valve stem
Old Dec 7, 2015 | 11:58 AM
  #1431
stogey420time
Club Moderator
the Hot Spot
I can understand why you'd want to use the OEM TPMS. The damn low tire pressure light (!) was driving me crazy. Thanks to my good friend P&K350z who helped me resolve the light issue by taping a square piece of an electrical tape over the low tire pressure symbol inside the gauge cluster and bam... no more light
Old Dec 7, 2015 | 12:02 PM
  #1432
Depravity's Avatar
Depravity
That light actually caught a severe leak I had in one of my tires on my GT-S wheels which saved it from being absolutely wrecked on the interstate I was about to get on. I'll figure out something here hopefully.
But yeah, the light bugs when there's no sensors currently in the wheels LOL
Old Dec 7, 2015 | 12:11 PM
  #1433
stogey420time
Club Moderator
the Hot Spot
Over the years, I developed a good habit of always looking over my tires before cruising. And since my car is low, if I scrape (more than usual) leaving the garage and drive way... is a good indicator my tires are low.
Old Dec 16, 2015 | 03:51 AM
  #1434
sofakiing's Avatar
sofakiing
18x10.5 square
IMG_8688 by sofa king, on Flickr
Old Dec 16, 2015 | 12:37 PM
  #1435
nizmo_0385's Avatar
nizmo_0385
Originally Posted by sofakiing
18x10.5 square
Winning!
Old Jan 11, 2016 | 01:48 PM
  #1436
ZRiderXlll's Avatar
ZRiderXlll
I'll throw my te37s in as well.
Old Jan 11, 2016 | 02:42 PM
  #1437
VenomGT9's Avatar
VenomGT9
I like them. Tire specs?
Old Jan 11, 2016 | 07:40 PM
  #1438
ZRiderXlll's Avatar
ZRiderXlll
Thanks! I got them from poison ivy. My buddy erik owns her.
They are 19x9.5-11 and 19x11-6 Porsche fitment. Tires are accelera 225/30/19 and 255/30/19.
I'm thinking of getting rid of the stretch and going toyo r888s just haven't decided size yet.
Old Jan 11, 2016 | 07:48 PM
  #1439
turboed350z
Just my boring double expresso
Old Jan 11, 2016 | 09:19 PM
  #1440
nizmo_0385's Avatar
nizmo_0385
So clean man. Not sure why i have t seen you around. Im in Tacoma.
