Will Tps Work In Volks?
Old Nov 11, 2003 | 01:05 PM
toykilla's Avatar
toykilla
Default Will Tps Work In Volks?
have some gt-7s on the was..will the tps work in them? .. i remember a thread along time ago about how to make TPS fit in any wheel but i cant find it..
Old Nov 11, 2003 | 01:10 PM
ares's Avatar
ares
Veteran
they fit in the TE37s without needing that band peice. just fit like stock.
Old Nov 11, 2003 | 01:25 PM
narkotic's Avatar
narkotic
Our volks use an angled valve, and when installing my GT-7's I coudln't figure out how to attach the TPS to it.
Old Nov 11, 2003 | 01:27 PM
toykilla's Avatar
toykilla
hmm different answers..
Old Nov 11, 2003 | 03:30 PM
jckolnturn's Avatar
jckolnturn
I have GT-7's and TPS but it wasn't easy, they need to band them in. I had to go back once to get them put back right because they came loose in my wheel. They banded them to the high part of the interior of the rim and after a high speed test run @140 they slid to the lower part i guess and came loose. They made real bad noise when going slow and the vibration from the wheels being out of balance was wicked. I've had them in for a while now and no problems once we figured it out. PS make sure you label them when you take them out and put them back in the same wheel!
Old Nov 11, 2003 | 04:36 PM
ares's Avatar
ares
Veteran
well I have TE37s, apparently not all volks are created equal in regaurds to valve setup.
Old Nov 11, 2003 | 04:54 PM
jckolnturn's Avatar
jckolnturn
the valve opening on GT-7's are in the center of the rim behind the spokes and have a 90 degree bent valve stem that comes through one of the spokes. I believe the te-37 have a setup almost identical to stock thereby allowing you to put the sensor in the stock location.
Old Nov 11, 2003 | 05:12 PM
rouxeny's Avatar
rouxeny
Tim, how'd you do it with the bands?
I think they might fit on some 18" wheels, but they'll need some mod to fit on 19's.
Old Nov 11, 2003 | 05:14 PM
MY350Z.COM's Avatar
https://my350z.com/forum/showthread....threadid=30147
Old Nov 12, 2003 | 05:21 AM
jckolnturn's Avatar
jckolnturn
on the picture below from the above link that's a home made band set-up, HRE and someone else actually make a kit to do the same thing with very similar parts. The hole in the middle of the rim is where the valve stem comes out to answer that other question.
