Another tire size question..
Old Aug 23, 2010 | 07:17 AM
rtiid22's Avatar
rtiid22
Default Another tire size question..
If I put 275/35-19 on a 10.5" wide rim would the rim stick out further than the tire? If so, what would be a more appropriate rim width to have a flush look?
Old Aug 23, 2010 | 08:35 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Your doing it wrong.
You mean:
Originally Posted by rtiid22
If I put 275/35-19 on a 10.5" wide rim would the rim stick out further than the tire? If so, what would be a more appropriate tire width to have a flush look?
And the answer would be: Not really, but get 285/35/19's anyway.
Old Aug 23, 2010 | 08:43 AM
rtiid22's Avatar
rtiid22
You mean:
Well, I haven't purchased the rims yet and 2nd, I was under the impression I'll have tire rub with 285s
Old Aug 23, 2010 | 09:04 AM
DavesZ#3's Avatar
DavesZ#3
It depends on which tires you buy, the offset of the wheels, if your car is lowered.
Old Aug 23, 2010 | 09:23 AM
rtiid22's Avatar
rtiid22
K. Sorry, wheel's +22 offset and depends on wheel gap I might lower an inch.
Old Aug 23, 2010 | 02:40 PM
The wheel is 275mm wide.
The tire tread is 266.7mm wide.
I think the bottom of the tire will stick out a little.
Old Aug 23, 2010 | 03:28 PM
GeauxLadyZ's Avatar
GeauxLadyZ
+22 on 10.5", lower 1.2" on 285, you may not rub depending on tire (if so, prob only over big bumps). 1.7"-1.8" drop, you will need fender roll on 285 depending on tire brand. Im using the BFG KDW as my guide, as it is known as one of the biggest sidewalls/treads.
285 KDW on 10.5" et.22 with 1" rear drop and rear camber set to higher end of factory spec range...you will not rub.
How's that?
Old Aug 23, 2010 | 03:41 PM
terrasmak's Avatar
275/35 is great for the flush look, as they are tastefully stretched on a 10.5 wheel, but to be flush you will need a 10 to 15mm spacer depending on your taste.
Old Aug 23, 2010 | 03:53 PM
GeauxLadyZ's Avatar
GeauxLadyZ
^ No way 10-15mm spacer....thats too much poke.
This is my buddies; 10.5" rear et.22 285/35 KDW's with no spacers. Perfect flush.
Old Aug 23, 2010 | 05:32 PM
Kuhan's Avatar
Kuhan
Depends on the tires, but I know Toyo T1R 285 is flush with 10" . Look for 295 or 305 for a flush look on 10.5" wheel width (however, might need fender pulled if going with 295 and above and lowered or aggressive offsets)
Old Aug 23, 2010 | 05:53 PM
rtiid22's Avatar
rtiid22
Thumbs up
Wow, good info guys. And thanks for the pics, that answers my question and looks great!
Old Aug 23, 2010 | 05:56 PM
rtiid22's Avatar
rtiid22
What size rims and tires is your buddy running up front?
Old Aug 23, 2010 | 05:57 PM
rtiid22's Avatar
rtiid22
How's that?
That's the perfect answer... Lol. Thanks.
Old Aug 23, 2010 | 06:10 PM
GeauxLadyZ's Avatar
GeauxLadyZ
He's running 19x9.5" et.22 with 255/35's, no spacers, dropped 1" in the front, and 1.2" in the rear with .5" springmount mod (so 1.7" drop in the rear).
Old Aug 24, 2010 | 06:13 AM
scotts300's Avatar
scotts300
That must be tight. My wife's ZR has 10.5" +18 with a 285 and it rubs on dips and the like (not lowered, no fender mod). I was going to change the spacer to net a +23 since it's getting lowered, but as it sits right now, it's too much spacer.
Old Aug 31, 2010 | 07:55 PM
GeauxLadyZ's Avatar
GeauxLadyZ
It is pretty damn tight. you can still fit a good finger between the tire/fender, but it does not rub at all with a fender roll.
