Varrstoen Wheels Thread
Old Jul 17, 2013 | 09:22 PM
  #1541
terrasmak's Avatar
Originally Posted by deftoneZ
Also camber hardly affects wear on tires, toe does. It will just make it wear on one edge of the tire.
Well the difference between 1 full degree of camber seems to be around 3k miles. So an extra 4 degrees , no dig deal.
Old Jul 17, 2013 | 09:28 PM
  #1542
nofrey's Avatar
nofrey
Whoa did I miss alot lol... hate it or love it, it makes no difference to me. I set up MY car to how I like because at the end of the day its my car, time and money.
Old Jul 18, 2013 | 07:23 AM
  #1543
driftsucky's Avatar
driftsucky
hate? Please read my sig line, it applies to you.
Reasons to do what i mention.
1. Proper height tires, speedo will read correctly. -Which only matters when you plan on speeding. 3-4 mph off won't get you a ticket that "proper" tires wouldn't have.
2. slightly higher ride height when the suspension is adjusted to the new tires.-new tires that aren't needed so that's a moot point.
3. With the higher height, you will gain ground clearance, making the car more drivable.- more drivable compared to what? If the car takes him everywhere he needs to go, why does it need to be MORE drivable. To that logic, if we lifted our cars to truck heights, it would make it even MORE drivable..until we hit that fine line between height and center of gravity.
4. Less camber wear to tires.-valid
5. Will have more suspension travel for a smoother ride, also safer for everyone out on the road.-the assumption is that his car is not smooth now. since this isn't the era of cut springs, MOST cars can ride low and be smooth. Obviously you feel the road more, but that does not negate smoothness. Under that logic, nobody should set their car up for track duty since that will reduce smoothness. I fail to see how that makes the car more or less safe.
6. Camber back to a reasonable area, more contact patch, making the car safer to drive and safer for everyone that shares the roadway.-semi valid in regards to contact patch and to debunk the argument of safety would be asinine on my part. Even though you're stretching on this, I'll give it to you.
I will leave it at that, I could probably come up with a few more. So what benifits are there to leaving it at the level it is now? It looks like an idiot picked the wrong offset wheels, and 2 year old set the suspension and the car is unsafe to the others around it.
SOOOOOOOOOOOOOOOOOOOOOOO, at the end of the day, you have 2(AT BEST) valid points. And they're a bit sketchy.
I'm done with it. I guess people will dislike what people dislike.
Old Jul 19, 2013 | 05:09 PM
  #1544
Cypher39's Avatar
Cypher39
I love the new color, Bro. Great job.
Originally Posted by basata
Old Jul 19, 2013 | 06:24 PM
  #1545
damagez33T's Avatar
damagez33T
Pull the spacers off, install a taller tire like the same width with 40 series aspect ratio, raise car slightly and adjust the camber to less gay specs and you will have a great looking car.
You sir, are a hater.
Old Jul 19, 2013 | 07:49 PM
  #1546
Bmurray350z's Avatar
Bmurray350z
^ Lol. You're an idiot.
Old Jul 20, 2013 | 05:38 PM
  #1547
driftsucky's Avatar
driftsucky
He seems accurate. I think it's safe to assume that Terrasmack hates stance. That, by definition, makes him a hater. I guess we're all a hater of something though. I hate silent farts. So when someone silent farts, I'm like "I HATE THAT I SMELL THAT AND DIDN'T KNOW IT WAS COMING!!!! HATEHATEHATEHATEHATE!!" and then they're all like "use a HATER" and I'm all like "SHO'U'RITE".
Old Jul 21, 2013 | 08:45 AM
  #1548
terrasmak's Avatar
Stanced cars sit a bit low for my taste , but a properly set up one is still nice. It just takes planning and skill unlike the slap together crap you see in the stretch and poke thread. I would still run proper height tires , still have stretch , run no more than -2 rear camber , try to match the front camber , run the ride height so the fender lip is even with the top of the tire.
Old Jul 21, 2013 | 03:25 PM
  #1549
driftsucky's Avatar
driftsucky
Nothing wrong with that setup. I think most people who do "stance" go for internet fame. I mean, my setup is WAY less functional than that, but there's two setups I've been contemplating that will be more functional yet still in that scope. That, and the performance mods I have planned deem it necessary. It's physically impossible to keep my car where it is and do what I ultimately have always wanted to do.
Old Jul 26, 2013 | 11:26 PM
  #1550
madril350z's Avatar
madril350z
Quick question do most people take out there fender liners? i am going to have to but is this the common practice just curious. Thanks
mine 19x9.5 19x10.5 +12 255/35/19 285/35/19
Old Jul 27, 2013 | 12:09 PM
  #1551
driftsucky's Avatar
driftsucky
You will need to remove your liners. The other option is to just drive until it rubs out. I wouldn't recommend that option though. It's loud and annoying.
Old Jul 27, 2013 | 12:13 PM
  #1552
sry110's Avatar
sry110
The white wheels look nice. Do you have some low-dust brake pads installed? And I would also recommend getting some Armor-All wheel protectant spray to keep those babies as clean as possible.
Old Jul 28, 2013 | 08:57 AM
  #1553
Dmad14's Avatar
Dmad14
Would love to see more pics of the ES6!
Old Jul 28, 2013 | 09:02 AM
  #1554
Bmurray350z
Here's another of mine
Old Jul 28, 2013 | 03:40 PM
  #1555
RawrXTC's Avatar
RawrXTC
How do 19's ride for you guys? I'm debating between 18's or 19's and I'm going to be lowered about 1.5" all the way around. Also between +12 and +22 which would look better? I heard 19's were rough, just wanted to know for sure. Also what size do you recommend for the height if I go with 19's? 35 series?
Old Jul 28, 2013 | 04:21 PM
  #1556
taryon's Avatar
taryon
When I changed from 18s to 19s, the difference was not noticeable to me at all comfort-wise.
I'd recommend 19x9.5/10.5 +12, more pokey setup than the +22, looks great.
Also I believe your tire knowledge may be wrong because sidewall height (eg 35) is an aspect ratio of the tire width and cannot be considered by itself without the width context
Old Jul 29, 2013 | 04:17 AM
  #1557
Nismopwr239's Avatar
Nismopwr239
Thumbs up
Varrstoen Es7
19x9.5+12
19x11+15
245-35-19
275-30-19
Enjoy...
Old Jul 29, 2013 | 09:41 AM
  #1558
RawrXTC's Avatar
RawrXTC
Thanks Taryon, what tire sizes do you have assuming you have the same wheel specs? I don't want to be too stretched so I don't think the usual set up of 245/35 and 275/35 will work. With +12 and being lowered only about 1.5" you think I'll have to roll the quarters and fenders or just the quarters?
Old Jul 29, 2013 | 04:50 PM
  #1559
taryon's Avatar
taryon
I do have those specs and I'm running a 255/35 and 285/35 lowered on HKS LS+ susp not too low though, rear clearance was an issue for me but kinda fixed by more fender rolling.
I'm not sure how much I'm lowered but a safe bet would be you would have to roll your rear fenders, not sure what you mean about the the quarters
Old Jul 30, 2013 | 04:24 PM
  #1560
BadBlu-Z's Avatar
BadBlu-Z
Default What offset on these ES1's? Pics Provided
Hey guys. So I found this Z that I fell in love with and didnt get a chance to talk to the owner but I wrote down the tire sizes. I love this beefy look and im planning on going with the ES1's set up just like you see in the pic. Could any ones expert judgment guess to what offset and wheel width he might be running? the tire sizes are 285/35 18 rears and 255/35 18 front. I really like how the fronts are tucked in a little so you can go nice and low, and how the backs are pretty flush. Gives an aggressive street/drag look in my opinion, which is what I would like. Any help would be great, Thanks!
