hey im new to Z and 19" wheel fitments. Im gonna buy a set of Varrstoen es1 wheels. Im just wondering if these would fit with a drop 19x9.5 and 19x10.5 on 245/35/19 and 275/25/19
Almost done with my z ..I seen these black Varrstoen te37 rep wheels 18x10.5 +0 all around.. I'm stock suspension wise ..would they rub? What would be the tires for it not to rub ...no fender rolling or anything like that has been done and don't want too...help before I buy...
Well TE's don't come in that offset so it doesn't apply. 19x10.5+12 was the most aggressive for that size and anyone that reads TE37's that has Varrshit won't click on your thread which in turn gets you no help. Using the correct title will attract the right people… common sense. To answer your question, you're more than likely going to rub and that'll be dependent on your tire choice… serious stretch and camber will be required to pull this off. It's going to look retarded unless you do serious fender work and drop it. Good luck and I say that with sarcasm… I don't really care.
