Varrstoen Wheels Thread
Old Feb 12, 2014 | 11:46 PM
  #1701
xirtam's Avatar
xirtam
I just bought a set of the ES2 18x9.5+12 and 18x10.5+12.
Now I need to get the tires. I'm planning on getting Hankook V12s.
I'm running stock suspension on my 05 350z.
What size tires do you guys recommend?
I've been told 245x40x18 in the fronts and 265x35x18 for the rears. Can I go 275 in the rears? Or is 265 good enough and won't require stretching the tire too much. Or is it safer to go with 265x35 and not have to roll my fenders?
I track the car occasionally, so I don't want to stretch the tires too much.
Old Feb 13, 2014 | 01:09 AM
  #1702
terrasmak's Avatar
265/35 front and 285/35 rear , or more of a street setup 255/40 front and 275/40 setup. The person who gave you advice knows little about this car.
Old Feb 13, 2014 | 02:54 AM
  #1703
taryon's Avatar
taryon
x2 on 265/35 and 285/35
Old Feb 13, 2014 | 06:09 AM
  #1704
Eriki's Avatar
Eriki
Looking for a quick response hopefully, on my g35 I have the es 2.2.2 19x9.5/11 ET 0 all around, on bc coils, spc camber kit, fenders rolled flat/slight pull. Right now I'm running 19x9.5/11 with 255/35 nankang NS-20(more like a 245 since it's narrow) and 275/35 nitto nt555 in the rear. I'm running -5.8 camber I'm the rear and still rub where the fender meets the bumper. I need to get a smaller tire in the rear so I don't rub it's chewing up the tire real bad on the outer edge.
Should I do a 255/35, 265/35 or do 275/30, tire dependent.
Here's what it looks like right now, I would like to have more stretch in the rear. Sorry for the big pics
Old Feb 13, 2014 | 09:06 AM
  #1705
xirtam's Avatar
xirtam
Thanks a bunch!
Old Feb 14, 2014 | 09:17 AM
  #1706
NVhim's Avatar
NVhim
Hi All,
I just ordered the following ES2's in a powder-coated textured matte anthracite finish and I was hoping I could get some quality input with which tire sizes to go with. I do not have brembos and I plan on lowering it in a few months too. Thanks!
Front: 19x 9.5 +30 offset (they were out of +22's so I might get 10mm spacers later)
Rear: 19x 10.5 +22 offset
Pics after they arrive
Old Mar 2, 2014 | 07:36 PM
  #1707
stak-overflo's Avatar
stak-overflo
What do you guys think of white ES2's with Michelin Pilot Super Sports for a Black '03? Mostly street use, with the possibility of being tracked once or twice per year. Figured I'd go with terrasmak's street sizes at the top of the page, here.
I'll probably pull the trigger on this tomorrow, I think...
Old Mar 5, 2014 | 06:22 PM
  #1708
Trevor Hebert's Avatar
Trevor Hebert
Anybody have any pictures of 19's rear, and 18's front?
I am thinking about running 18x10.5+15 front, 19x11+15 rear with 255/35/18 front, 275/35/19 rear.
It'd be the ES1 wheels.
Reason is i want to go lower in the front.
Any input would be great!
Old Mar 10, 2014 | 08:07 AM
  #1709
Zac350's Avatar
Zac350
Default New Wheels Need Help
I am looking to get a set of new Varrstoen 350Z ES2 TE37 Replica Wheel Set - 19 Inch and I'm not sure what offset or width I should get. I want the wheels to be close to flush with my fenders and 1/4 panels but not enough to need them rolled. I also don't want flush or stretched tires.
19x9.5 +30 5x114.3
19x9.5 +22 5x114.3
19x9.5 +12 5x114.3
19x9.5 +0 5x114.3,
19x10 +25 5x114.3
19x10 +15 5x114.3
19x10.5 +30 5x114.3
19x10.5 +22 5x114.3
19x10.5 +12 5x114.3
19x11 +25 5x114.3
19x11 +15 5x114.3
19x11 +0 5x114.3
Those are the choices I have for sizes.
any help would be greatly appreciated.
Old Mar 10, 2014 | 08:39 AM
  #1710
CJM's Avatar
CJM
https://my350z.com/forum/2003-2009-n...questions.html
Please read post 8
Old Mar 10, 2014 | 06:30 PM
  #1711
xmartyx's Avatar
xmartyx
So I've looked through the 86 pages of this thread and have found conflicting posts. I'm looking to get some ES221's, 18x9.5 +12, 18x10.5 +15. Thinking 245/40, 275/40, maybe 265/40 so the speedo is right on, but I'm not sure yet. I'll be at stock height and don't plan to lower. Will I need to roll fenders or no? I've seen people say they didn't need to, but others said they did. The listing says it's required as well. Thanks for any help.
Old Mar 10, 2014 | 06:52 PM
  #1712
Bmurray350z's Avatar
Bmurray350z
Yes you'll want to roll fenders.
And for speedo to be as close as possible, you'll want 255/40 Front and 275/40 Rear.
Old Mar 10, 2014 | 07:49 PM
  #1713
xmartyx's Avatar
xmartyx
At stock height? Damn. Then I guess what would be my best bet to avoid rolling? Would a +22 be fine?
Old Mar 10, 2014 | 07:55 PM
  #1714
CJM's Avatar
CJM
Just roll them. It will be nice to have them rolled so you can have a better offset wheels and if you ever want to lower your car, you won't have to deal with it later. Plus, you guarantee that you won't rub on hard cornering, bumps and with a lot of weight in it.
Old Mar 10, 2014 | 08:11 PM
  #1715
Bmurray350z
+22 won't be as flush. You want +15. Just roll your fenders as mentioned above. Get it out of the way. Rent a tool and diy (take your time and it's not that bad), or pay somebody to do it.. usually not more than $40-50 per fender.
Old Mar 10, 2014 | 10:57 PM
  #1716
xirtam's Avatar
xirtam
I run ES221 on my 05 Z with stock suspension with upgraded Akebono BBK.
Fronts: 18x9.5 +12
Rears: 18x10.5 +15
Tires:
245x40R18
265x40R18
Didn't need spacers or rolling of my fenders. Tire setup is close to stock so my speedo is pretty accurate.
Old Mar 11, 2014 | 08:16 PM
  #1717
Broseph Stalin's Avatar
Broseph Stalin
Anybody know the owner or wheel specs?
Old Mar 12, 2014 | 02:02 AM
  #1718
terrasmak's Avatar
Cosmos wheels I believe
Old Mar 12, 2014 | 11:46 AM
  #1719
Broseph Stalin
cosmis or cosmos? I cant find anything on cosmos wheels
Old Mar 12, 2014 | 03:25 PM
  #1720
SR71's Avatar
SR71
Lead Super Moderator
https://www.cosmisusa.com/
But that's not what they are.
