Where 2 buy longer wheels studs?
Old Nov 13, 2003 | 11:21 PM
350ed's Avatar
350ed
Professional
Default Where 2 buy longer wheels studs?
Hi folks, I'm adding ~10mm wheel spacers on the front and need longer studs. Can someone help with a weblink?
With searching I found out they are 12x1.25 and are about 45mm long now. I think I need an extra 20-25mm length.
Thanks in advance.
Old Nov 14, 2003 | 05:54 AM
twenzel's Avatar
twenzel
if you are adding 10mm spacers wouldnt you need just 10mm more? I dunno where to get them though. I want these too because I plan to add spacers myself.
Old Nov 14, 2003 | 06:28 AM
EL PAALO's Avatar
EL PAALO
www.summitracing.com
http://store.summitracing.com/search...art=wheel+stud
search for wheel stud or lug stud. other places have them too.
Old Nov 14, 2003 | 06:32 AM
EL PAALO's Avatar
EL PAALO
http://www.diamondracingwheels.com/D...Nuts&Studs.htm
http://www.steeda.com/store/-catalog/wheelstuds.htm
http://www.hardwaychassis.com/catalog3.htm
Old Nov 14, 2003 | 07:02 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
We have the NISMO long hub bolts.
The ones you are $56.95
We have either 13.0/60 or 14.3/60
Let me know if that will help you. each set comes with 10 bolts.
parts@perfnissan.com
626-305-3000 x259
Old Nov 14, 2003 | 07:03 AM
350trackz's Avatar
350trackz
Default Crawford Z
Doug has some custom made for the Z. call him. I think they are Moroso, but I could be mistaken.
Old Nov 15, 2003 | 09:24 PM
350ed's Avatar
350ed
Professional
tonywenzel,
I'd like more than 10mm because I don't think the current # of thread turns engaged is enough on my iForged wheels (~5 turns) versus stock 9 turns. I figured 20mm extra would be perfect.
EL PAALO,
It's not clear to me which are the ones I should get. I'd like to keep the factory lug nuts, but it's not required. I don't want to drill the hub either.
I guess I need the Knurl diameter and length of the stock hub first... anyone know?
Jason,
How do 13.0/60 or 14.3/60 differ from stock? I guess 15mm longer but is 13/14.3 the diameter. Would I need to drill out the hub?
Something so simple is complicated
Thanks!
Old Nov 15, 2003 | 10:12 PM
Jason@Performance
Performance Nissan
Originally posted by 350ed
tonywenzel,
Jason,
Thanks!
Honestly. I have no clue what the difference is.. All 3 packs of wheel studs were sitting in front of me and I was trying to see a difference.
Nothing just from looking at them. I didnt measure.
Old Nov 15, 2003 | 10:24 PM
350ed's Avatar
350ed
Professional
I'm guessing it's the number of threads per inch.
So stock are 12/1 whereas those are 13 or 14.3/1.
See it now?
Old Nov 15, 2003 | 10:26 PM
Jason@Performance
Performance Nissan
oh that makes perfectly good sence!
:thumbs up:
Old Nov 17, 2003 | 10:44 PM
350ed's Avatar
350ed
Professional
Anyone buy the Nismo studs? Did you require new lug nuts? What did you get? Adapter for lug wrench??
THANKS!
Old Nov 18, 2003 | 03:53 AM
Jason@Performance
Performance Nissan
We were holding them up to a set of stock lugs yesterday. I need to pull a set of stock lug nuts and see if they fit on the nismo studs. It looks like they would. But at some point I will try it today.
Old Nov 18, 2003 | 08:29 AM
N74DV's Avatar
N74DV
See it now?
nope.... the studs on our car are metric. Metric does not measure the "threads per inch". They use a Pitch measurement. Our studs are 12mmx 1.25 pitch.
The 13 and 14.3 is knurled diameter in mm. On older Z's the front and rear studs had a different knurled diamter. I think the 350Z is the same.
Old Nov 19, 2003 | 09:56 PM
350ed's Avatar
350ed
Professional
ahhh, that makes sense. I guess the question now becomes is 13mm the stock front diameter and 14.3 the stock rear?
Jason, I need the front so let me know if the 13's are right and I'll buy them. Let me know if your tech knew how to replace them:
https://my350z.com/forum/showthread....&postid=534851
Thanks,
Ed
Old Nov 20, 2003 | 06:17 AM
Jason@Performance
Performance Nissan
OK,
I took a picture of the FRONT and REAR STOCK bolts that are on the Z. Below are the LONG HUB BOLTs that fit the same Lug Nuts.
I hope this helps. Ill ask a tech when they get in, I missed yesterday sorry.
Will do today.
Old Nov 20, 2003 | 10:39 AM
Topics II's Avatar
Topics II
how much is a set of those? and how much longer is the front and the rear over the stock length?
Old Nov 20, 2003 | 10:42 AM
Jason@Performance
Performance Nissan
50mm $54.00 for 10
60mm $54.00 for 10
Old Nov 20, 2003 | 10:55 AM
Topics II's Avatar
Topics II
so 60s for the front and 50s for the rear im assuming? how much longer than stock are they?
Old Nov 20, 2003 | 11:02 AM
Jason@Performance
Performance Nissan
Front = 1 5/8"
Rear = 1 3/4"
13.0/50 = 2 1/8"
13.0/60 = 2 1/2"
sorry it took me a while to measure them, costumers
Old Nov 20, 2003 | 11:56 AM
Topics II's Avatar
Topics II
Originally posted by Jason@Performance
Front = 1 5/8"
Rear = 1 3/4"
13.0/50 = 2 1/8"
13.0/60 = 2 1/2"
Thanks!
