How low I can go with 305 tire?
I have 305/30/19 tires on 19/10.5+22 rims in back,and my fenders are already rolled.
Can someone move this to brake and suspension fourms
Since you already have the tires and wheels why don't you mount them and then start lowering the car to see how far you can go?
Otherwise bist out the old measuring tape.
Agree. I have yet to figure out why members ask such questions. You have the wheels-tires. You have the car. Not me.
no one knows what tire you have (size is of little consequence)
no one knows your current alignment specs
as such, no one knows the answer to your question
plan on it rubbing at ANY height...if it doesn't, you lucked out, if it does, it was expected from the get go
I was simply speaking by experience with (large) 305 PS2 tires. The 305/30 is a relatively short tire, and with the additional clearance (~8mm) from the fender rolling, he should be ok, or darn close to it given the alignment unknown.
Not to thread jack..but can i put on 305/30/19's in the rear without any modifications?
Car is stock height
im running 275's in the back but am looking for a fatter tire with more presence.
Car is stock height
It depends primarily on wheel size and offset, followed by how wide that particular 305 is and your current camber. We can't begin to guess without at least the first two bits of information.
And thanks
19X10 1/2 Rear + 22 off set
305 30 19
Thanks in advance
350Z_Al
Oct 29, 2020 07:44 PM
