lugnuts keep loosening
Old Aug 7, 2015 | 07:37 AM
  #41
turboed350z's Avatar
turboed350z
Originally Posted by infoparazite
I'm not positive but I think it could be the bore of the studs? Not thick enough for the hub?
Did you buy actually studs meant for the 350z? Or did you just buy whatver studs?
Old Aug 7, 2015 | 07:54 AM
  #42
travlee's Avatar
travlee
Master
replace the hub
Old Aug 7, 2015 | 08:21 AM
  #43
infoparazite's Avatar
infoparazite
I bought them a wicked long time ago so the actual info is on my pc (not currently with me) but almost positive I bought them off zspeedperformance.com H and R studs with 14.25 knurl 45mm thread length and 12X1.25 thread. I thought those were the right ones?
Last edited by infoparazite; Aug 7, 2015 at 10:01 AM. Reason: had to include quote
Old Aug 7, 2015 | 10:00 AM
  #44
infoparazite
travlee you def think its the hub
Old Aug 7, 2015 | 10:22 AM
  #45
travlee's Avatar
travlee
Master
you could spend all this time jacking with it, or simply replace it.... up to you
Old Aug 7, 2015 | 10:29 AM
  #46
infoparazite
I def don't want anymore time spent on this little issue. I haven't been able to drive my z for 2 weeks because I couldn't figure it out. Thought it was the lugs...replaced em...thought it was the studs...replaced em....guess my last option is the hub?
Old Aug 7, 2015 | 01:50 PM
  #47
nizmo_0385's Avatar
nizmo_0385
With trav on this one
Old Aug 7, 2015 | 02:12 PM
  #48
infoparazite
Okay thank you guys. Very helpful. I'll research the right hub and get it on there. I'll post how it goes and if this is the solution.
Old Aug 7, 2015 | 03:21 PM
  #49
MicVelo's Avatar
350Z/370Z Tech Moderator
JDMStanced please let me know what happened. I know this post was 5 years ago but my studs tighten into my hub then fall out with little pressure. One of them also won't tighten into the hub. ( I seat it in the hub then the bolt grabs it and the bolt and stud spin together forever)
replace the hub
^^^ With Trav on this but consider that the studs are probably the wrong size (spinning in the hub) OR the hub holes have worn to the point of not providing proper fit/grab for the studs (correct size or not). Don't know how this could happen but I've seen stranger things.
Old Aug 7, 2015 | 04:58 PM
  #50
StevSam's Avatar
StevSam
I had a similar problem before. When I had my stock wheels, the lugs were bottoming out for some reason. I ended up going with open ended lugs. That could be the problem, but I'm with everyone else on changing the hubs. Good luck!
ablaine
Nov 29, 2016 10:13 AM
drsifu
Dec 19, 2015 04:08 PM
John
Sep 4, 2013 04:38 AM
drsifu
Jan 20, 2008 03:05 PM
all_bark
Feb 22, 2004 11:11 AM
