Need help with my setup !! for speed pumps in Kuwait
Old Jan 4, 2011 | 04:36 PM
350z-900whp's Avatar
350z-900whp
Exclamation Need help with my setup !! for speed bumps in Kuwait
hi guys,
first of all i just recived my car from US ..(now in kuwait). my car is lowered with JIC coil-over A2 flat about 1.5 inch lower than stock 350z and i have been told that the highest setting for this coil-over. tires used 295/30 toyo r888 R , F 265/35 toyo r888 on 9.5F and 10inch rear volk rims.
to the subject, do to the street speed bumps her in kuwait my car just scrape the exhaust each time i go over one , and i don't want to heavily damage my exhaust each time i go over one with the time
so, what the best way to rise the hight of the car ? and can i do it while i still maintain or keep my coil-overs ??
i was thinking of two things going back to stock suspensions and maybe use some 40F and 45 rear tire if possible ?
thanks for u help in advance
Attached Thumbnails Need help with my setup !! for speed pumps in Kuwait-04cd814cf1548a.jpg   Need help with my setup !! for speed pumps in Kuwait-04cd8145875bbe.jpg   Need help with my setup !! for speed pumps in Kuwait-imag0078-1024x768.jpg   Need help with my setup !! for speed pumps in Kuwait-p1020673.jpg   Need help with my setup !! for speed pumps in Kuwait-p1070548-19-51-03.jpg
Old Jan 4, 2011 | 04:40 PM
350z-900whp
some sample of speed bumps
Attached Thumbnails Need help with my setup !! for speed pumps in Kuwait-imag0077-1024x768.jpg   Need help with my setup !! for speed pumps in Kuwait-imag0078-1024x768.jpg   Need help with my setup !! for speed pumps in Kuwait-846214604958.jpg
Old Jan 4, 2011 | 04:53 PM
350Z_Al's Avatar
350Z_Al
You could get over all of those with that car (except that last crazy one) if you go over them at an angle.
Old Jan 4, 2011 | 04:57 PM
terrasmak's Avatar
Post pics of the coilovers installed on your car in current form , also what size wheel 18 or 19? I bet you can lift the car up slightly.
350z-900whp
actually these in the pic the good mold ones except the last but even with good mold my car still scrape badly ( with huge cation taken of course ) so, i just parked it until i figure out something
those are 18s, as i mentioned i remember Rick at "status auto design" told me that the highest setting he could left the car to. ( that was when i where in the states)
Old Jan 4, 2011 | 04:58 PM
350Z_Al's Avatar
350Z_Al
Have you tried going over at a 45 degree angle?
Old Jan 4, 2011 | 04:59 PM
sdZ33's Avatar
sdZ33
Yea, I think you will teeter-totter on the speed bump in the last pic...
Old Jan 4, 2011 | 05:03 PM
350z-900whp
yes i have tried 45 degree angle some i could get over and other's can't
the maine problem is that each speed bump is different some good and others very bad mold
Old Jan 4, 2011 | 05:47 PM
The lowered Z is cool, but often there is a trade off. Sometimes the bottom of the car gets beat to shiit.
I do NOT recommend that you alter ride height with tire height. This will increase axle-ground clearance. It is unnecessary and unwanted.
Get yourself some OEM springs and dampers.
Old Jan 4, 2011 | 05:56 PM
skakemokid's Avatar
skakemokid
What exhaust do you have? That has alot to do with it.
Old Jan 4, 2011 | 06:52 PM
350z-900whp
i have greddy exhaust tic 2.75 inch and huge rear mufflers .
why not use bigger or taller tires
my tire spec
R 295/30 on 10inch 18 is a 25.1 Overall Diameter (inch)
what am looking at is
toyo r888
R 305/35 on same rim the overall diameter (inch) would be 26.3 which is a 1.2 inch taller
But am not sure about the clearance ( if tire would rube or not ) even with stock hight ?
R 275/40 toyo R888 26.7 overall diameter (inch)
mickey thompsontires
R305/45R18 SizeEquivalent (29X11.50R18) rims range 9.5-11.0 overall diameter 28.8
this one is what am interested
for front
toyo r888
with 18s 9.5inch 275/40 diameter 26.7
F 18 265/40 diameter 26.5
the quistion is would they fit with my suspension or stock suspension?
Old Jan 4, 2011 | 06:55 PM
350z-900whp
am not really looking for look right now. what i want is to drive my car and not worry about speed bumps each time i see one.
even if that meant to take of my coil-overs
Old Jan 4, 2011 | 07:07 PM
terrasmak's Avatar
Do the 305/35 rears and bump up to the 275/35 fronts.
Old Jan 4, 2011 | 07:16 PM
350z-900whp
they don't offer 275/35 only 40s toyo R888 in 18s
would something with 28.8 diameter fit on Z ? 305/45 18s
or maybe nitto with 28.6 ?
about your setup would i still keep my coil-over or not just asking ?
Old Jan 4, 2011 | 08:01 PM
tribal_visionz's Avatar
tribal_visionz
i would have gone with a temporary vehicle
Old Jan 4, 2011 | 08:17 PM
terrasmak's Avatar
Thats funny i was looking at the Toyo website when i made my post http://toyotires.com/tire/pattern/proxes-r888 . And yes, keeping everything on your car as is, you would gain a bit of height. Also your coilovers, most people don't know how to set them up. You can probably lift the car a bit with them.
Old Jan 4, 2011 | 08:18 PM
350z-900whp
its not may daily car just my weekend now that am here i drive a saloon caprice-v8 2006 or her could holden
also, its heavily modified so i don't want to wast my money just because of the car hight (545whp) and 685whp on 110 octane
Old Jan 4, 2011 | 08:25 PM
350z-900whp
i guess i missed them :P sorry
its not much differ in terms of hight between 275/35 and mine now 265/35 is about .3 inch
would the .3 make a notice able difference ? ( i don't think so )
rather than 275/40 which is a 1 inch taller 26.7 to 25.7
am not arguing her just looking for more info before i dump a load of $$
Old Jan 4, 2011 | 08:54 PM
skakemokid's Avatar
skakemokid
Possible its your resonators making a mess of things. I have a greddy ti-c single and the resonator is the worst design possible. Its .5 inches from the drive shaft and the bottom is the lowest part of the car. Ive been planning to get rid of it and use a bottle type resonator to get some extra clearance. Maybe thats your problem.
Old Jan 4, 2011 | 09:49 PM
scotts300's Avatar
scotts300
No way on the 305/45, that is a horrible tire for a Z.
I think you have to split your calculated tire height increase by 2, since half the tire is above the axle and half is below.
Easiest thing, I think, would be to replace the coilovers with stock shocks and springs for now. Also, why do you need R888s for the street?
