Rotating S-03 tyres
Old Jan 6, 2011 | 08:32 PM
Aust350z's Avatar
Aust350z
Default Rotating S-03 tyres
A currently have a set of Bridgestone S-03 tyres on my Z. The fronts are fine but the rears are starting to get a little uneven wear (camber). Inside is prolly 2mm above the wear indicator. Shoulder is roughly 5mm above wear indicator.
Google has told me that my tyres are directional and not asymetrical and therefore my logic tells me that I should be able to remove the tyre from the wheel and move it to the other side of the car to even out the wear and not compromise safety/performance.
Is there any reason I shouldn't do this?
Old Jan 6, 2011 | 08:45 PM
kemps's Avatar
kemps
wont be good for wet/slippery road conditions
Old Jan 6, 2011 | 09:49 PM
Aust350z's Avatar
Aust350z
This would only be an issue if I did not have the tyre rotating in its intended direction though? As I'm physically removing the tyre the direction will be the same.
If I look towards the back of the car I'd see this before and after the swap.
Old Jan 6, 2011 | 09:57 PM
kemps's Avatar
kemps
my mistake, shouldn't be a problem if you just swap the tires
Old Jan 6, 2011 | 09:58 PM
scotts300's Avatar
scotts300
Don't S03 tires say "inside" and/or "outside" printed in block on the tire?
Old Jan 6, 2011 | 11:22 PM
Aust350z's Avatar
Aust350z
I had a close look last night and could only see "directional" arrow. However I'll look again tonight.
Old Jan 7, 2011 | 12:16 AM
Swap is a good idea. Inside to outside. Outside to inside.
Old Jan 7, 2011 | 08:53 AM
scotts300's Avatar
scotts300
I think you are good to do with swap with the S03 tires as well. I don't think they have an inside and outside label on them.
Old Jan 7, 2011 | 06:38 PM
Aust350z's Avatar
Aust350z
To confirm - this is correct. S-03 tyres are not inside/outside dependant and CAN be rotated as described in this thread.
Unfortunately for me it didn't matter in the end and I came home like this
All thanks to this little baby (which could have been fixed) but the crumbling sidewall has put the tyre to the the scrapyard.
I guess its time to hit up the forum sponsor Tirerack for some replacement tyres. I've always been told to run the same pattern tyre front and rear. Guy at the tyre centre said its not necessary front and rear (particularly on performance cars given rear wear) but must keep left/right same at front and back. I just bought a house so not really keen on cost of 4 new tyres. What are people's thoughts? Ok just to replace the rears?
Currently swapping wheels for my stockies in the meantime but the tread on these are nearly shot too.
Old Jan 7, 2011 | 07:13 PM
scotts300's Avatar
scotts300
Wowzers. . .!
Replacing just the rears is no prob. I'd help you with tires, but shipping to AUS - yikes! Aren't there any local sources besides TR?
Old Jan 7, 2011 | 07:17 PM
Aust350z's Avatar
Aust350z
Not what I was expecting to start my Saturday!
Also local suppliers can't get close to the prices TR sells them shipped for. Go the Aussie dollar
416blueZ
Jun 11, 2024 10:56 AM
416blueZ
Sep 24, 2015 02:11 PM
Shane86
Sep 17, 2015 05:33 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
