stock 350z wheels...is this normal...???
Old Jan 19, 2011 | 09:26 PM
cnp112's Avatar
cnp112
Default stock 350z wheels...is this normal...???
could someone please help me out...my wheels look like they are hellflush (at least I think thats what its called)...they look angled...the top of the wheel (towards the sky) is more inward to the car and the bottom of the wheel (towards the ground) is more outwards to the car...
is this normal for a 2007 stock 350z...
Attached Thumbnails stock 350z wheels...is this normal...???-img_2465.jpg   stock 350z wheels...is this normal...???-img_2464.jpg   stock 350z wheels...is this normal...???-img_2460.jpg   stock 350z wheels...is this normal...???-img_2463.jpg
Old Jan 19, 2011 | 09:51 PM
Chebosto's Avatar
Chebosto
they are hellanotflush.
top of wheel inward to the car is called negative camber.
normal camber for the rear is -1.2ish.. you actually might have more than that.. there is an illusion of alot of negative camber when you put a high offset wheel in the rear, since our fenders come out..
you would probably need to add a 25mm spacer if you want to be 'hella flush'
Old Jan 19, 2011 | 10:24 PM
kemps's Avatar
kemps
far from hellaflush, more like hellasunk
Old Jan 19, 2011 | 11:56 PM
marques1's Avatar
marques1
hellaflush my ***, lol.
Old Jan 20, 2011 | 12:07 AM
bbs350z's Avatar
bbs350z
lol, those are the nissan aftermarket wheels correct? those look pretty sunken in there. find the offset on the back of the rim, and post up. well find you a spacer to bring it out some. should you go with a spacer, go with a pre pressed hubcentric like the ichiba v2.
Old Jan 20, 2011 | 02:12 AM
Ghalleo's Avatar
Ghalleo
LMAO!
Old Jan 20, 2011 | 02:54 AM
laser24's Avatar
laser24
well while were on this subject,, what spacers do you need for factory 07 wheels to bring them out hellaflush with out risk of scrubbing fender well?
Old Jan 20, 2011 | 03:27 AM
08panna's Avatar
08panna
This is contradictory. best advice is to measure out from the top of the tire to the fender and decide how much you want to come out
Old Jan 20, 2011 | 06:00 AM
cnp112's Avatar
cnp112
lol...sorry about the comparison to hellaflush...searched around and its obviously not...
but is this normal for a stock Z...to be sunken in that much...thanks...
Old Jan 20, 2011 | 06:04 AM
cnp112's Avatar
cnp112
ahhh...i see clearly now...thanks chebosto...i just wanted to know if it is normal for a stock z and it seems it is...hellaflush would be more if the top of the wheel was in line with the fenders...is this correct...
Old Jan 20, 2011 | 06:20 AM
drivessidewayz's Avatar
drivessidewayz
Hellaflush is looked down upon by many people and others love it, so tread carefully. It is when people buy 12" wide rims and 245 tires and lower their car without camber correction until it almost sits on the sidewall of the tires.
And yes, that look is normal for a stock Z.
Old Jan 20, 2011 | 08:44 AM
D&G35's Avatar
D&G35
add 25mm spacers all around and that shud help bring out the wheels more...it also depends on how low your car is now too...g/l man...
Old Jan 20, 2011 | 10:40 AM
terrasmak's Avatar
Don't wast money on spacers, use that money on wheels that are not chrome.
Old Jan 20, 2011 | 12:07 PM
cnp112's Avatar
cnp112
^^ lol...i agree...how much would i be looking at for new wheels...any suggestions which are budget friendly...thanks...
Old Jan 20, 2011 | 03:53 PM
Barnabas's Avatar
Barnabas
National Z Club President
What is your goal for the car? Rims without tires can range from 800 a set for cheap knockoffs to 6000 a set for goood baller lightweight wheels. Most will suggest volks or something around the same caliper which are about 3xxx a set new.
it is best to just browse the market place until you find a set you like, then ask questions about that rim specifically. then decide if thats what you want to buy.
Old Jan 20, 2011 | 04:05 PM
drivessidewayz
<3 Enkeis myself. Those are like $1300-1500 a set and rather light.
Old Jan 20, 2011 | 04:54 PM
Very unusual. Maybe something is bent.
Old Jan 21, 2011 | 07:06 AM
F34RL355's Avatar
F34RL355
those wheels make me wanna puke, skip the spacers and get new wheels
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
