fittment question, new rims and tires
Old Jan 21, 2011 | 11:23 PM
lillong1991's Avatar
lillong1991
Default fittment question, new rims and tires
I got a 05 redline. i just but new rims and spring. not sure what tires to get yet, any suggestions? not trying to spend over 700 for tires. anyways i got XXR 521 with gold rivits. they are 18x8.5 in the front and 18x10 in the rear and i got roadmagnet springs that lower the car 1.75 inches. should i have any clearence issues? also what size tires should i get? im thinking 225/40/18 for the front and 265 or 275/35/18 for the rear.
Old Jan 21, 2011 | 11:35 PM
Arvin89's Avatar
Arvin89
dont know about what brand tires, but id say get wider tires go.. 245/35/18 front and 285/35/18 in the rear. Read up on the tire threads a bit more,theres many, itll explain everything, i think you need to understand tire sizing a bit better. You were gonna get taller tires for the front if you get 225/40/18 instead of 225/35(same as rear)/18
Old Jan 21, 2011 | 11:58 PM
lillong1991
so your saying that i should have all the tires have the same size wall? also you dont think i should have any clearance issues do you?
Old Jan 22, 2011 | 12:47 AM
terrasmak's Avatar
245/40 and 275/40 would be proper fitment
Old Jan 22, 2011 | 02:59 AM
Actual speed 100.0 MPH. Speedometer will read 104.3 MPH.
Old Jan 22, 2011 | 04:54 AM
pangoman's Avatar
pangoman
I don't know of ANY springs that will drop 1.75". In any case, you had better do more research because you're going to need a lot more than what you bought if your car is going to drop even an inch or more.
Old Jan 22, 2011 | 03:58 PM
gZ33's Avatar
gZ33
+1.... your looking at serious camber and toe problems going that low and for a front and rear camber/toe kit unless you find it used your looking at the 500 dollar range. I got my front and rear SPC kit from a vendor here on the forum. Great kit for the money and was a fairly simple install.
Old Jan 23, 2011 | 04:17 AM
vTxSpikeZ's Avatar
vTxSpikeZ
Not trying to jack thread or anything but does anyone know if you can run 18/10 in the front with no problem at all? Because I am planning on running 10's all around with maybe staggered tires setup please let me mnow
Old Jan 23, 2011 | 11:45 AM
terrasmak's Avatar
Been done, looks great.
Old Jan 23, 2011 | 02:00 PM
vTxSpikeZ's Avatar
vTxSpikeZ
So I wouldn't need to get any camber kit or anything for the front correct? Sorry man noon questio. Lol
Old Jan 23, 2011 | 02:12 PM
Waiz's Avatar
Waiz
Roadmagnet springs? Where were these purchased? I've never heard of them.
Old Jan 23, 2011 | 02:55 PM
terrasmak's Avatar
nope, just install and roll. You can easily run 255/40-18's or 275/35-18's on them up front.
Old Jan 23, 2011 | 04:37 PM
black_03's Avatar
black_03
That's what I was thinking....
Old Jan 23, 2011 | 05:22 PM
vTxSpikeZ's Avatar
vTxSpikeZ
Thanks terra that's great info
Old Jan 23, 2011 | 06:11 PM
Spike100's Avatar
Spike100
Judging from your questions, you definitely are wise asking for help.
For wheels sizes you are purchasing (“… they are 18x8.5 in the front and 18x10 in the rear”), the tire sizes you are considering (“im thinking 225/40/18 for the front and 265 or 275/35/18 for the rear.”) are all wrong.
Better tire sizing is 245/40-18” on your new front 18x8.5” wheels. For your new 18x10” rear wheels, consider using either 275/40-18” or 285/40-18” tires. You can go even wider if you pick the correct profile.
RE:> “and i got roadmagnet springs that lower the car 1.75 inches.”I doubt that the drop is 1.75”. It’s probably 0.75”
RE:> “should i have any [clearance] issues?”That depends upon the wheels’ offsets, and you do not provide that figure so it’s not possible to answer this question.
--Spike
Old Jan 23, 2011 | 09:51 PM
lillong1991
i just got the correct info on them, they lower it 1.1 inches in the front and 1.3 in the rear. i bout them from my friend who sells them. they are based out of baltimore, maryland. they cost $235 but they got a deal for $40 off till the end of january
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
