quick offset question
Jan 27, 2011 | 05:35 PM
ordred some savini sv-23's
front rim is 20x8.5 15et, 4 inch lip, rear is 20x10, 20 et with 5.5 inch lip.
I didn't think about it till now(dumb i know) but is the front rim going to stick out? just curious.
Jan 27, 2011 | 05:44 PM
Use a
offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference:
http://www.1010tires.com/WheelOffsetCalculator.asp
Jan 27, 2011 | 05:47 PM
You'll be fine. Front's won't stick out at all... I had 19x8.5 +20 and I'm down to a 19x8.5 -5 now... You're worrying for nothing, you'll be good.
Jan 27, 2011 | 05:51 PM
thanks for the links and responses, i haven't bought rims in 3 years so I've forgotten EVERYTHING
Jan 27, 2011 | 05:55 PM
Quote:
Originally Posted by
jray8
No problem. Specs such as lip can be a bit confusing. Lip will NOT alter the position of the wheel. Neither will diameter.
Jan 27, 2011 | 06:02 PM
Post pictures when you get'em mounted.
Jan 27, 2011 | 06:07 PM
OK
TheFarmer
Will do, but only if it looks good of course
Jan 27, 2011 | 06:09 PM
Super Moderator MY350Z.COM
They will look like they belong on some homie's SUV.
Jan 27, 2011 | 06:23 PM
if thats the case, i have 100% ebay feedback, they will find their way there
Jan 27, 2011 | 06:24 PM
Not even close to poking.
Jan 28, 2011 | 05:18 AM
you'll need spacers just to get them flush.
Jan 28, 2011 | 06:54 AM
you'll need a 30mm spacer on top of a 20 mm spacer to make them flush. That would be like a 10 wide wheel with et0.
issyz
Jul 2, 2017 03:04 PM
