Air leak between tire and rim
Old Jan 28, 2011 | 01:09 PM
RedBird's Avatar
RedBird
Default Air leak between tire and rim
I have tried having the rim fixed which lasted for a while but then started leaking again, does anyone know of a sealant that I can use for this?
Old Jan 28, 2011 | 01:14 PM
350zspl's Avatar
350zspl
submerge entire wheel under water
isolate leak location
then take best plan of action for repair
Old Jan 28, 2011 | 02:09 PM
DavesZ#3's Avatar
DavesZ#3
Define "rim fixed".
Old Jan 28, 2011 | 02:31 PM
Spike100's Avatar
Spike100
RE> "I have tried having the rim fixed which lasted for a while but then started leaking again..."
If it's leaking again, obviously it isn't "fixed."
RE> "...does anyone know of a sealant that I can use for this?"
I wouldn't do that. Any sealant you use will likely fail (sooner than later) when the tire heats.
I assume you hit a curb or pothole that necessitated the repair. I'm guessing here, but really think you need a new wheel. I would check the tire first though since it might simply be a problem with the tire.
--Spike
Old Jan 28, 2011 | 06:30 PM
What size wheel?
What size tire?
Old Jan 28, 2011 | 06:39 PM
-miltdoggie-'s Avatar
-miltdoggie-
If your tire shop knew what was up they would use bead sealer..
Old Feb 2, 2011 | 04:48 PM
Never mind. I thought this was important. Important enough to say “thanks” or simply reply.
Old Feb 3, 2011 | 07:29 PM
RedBird's Avatar
RedBird
Filled the tire back up with air and it's been holding since I wrote this, but I do remember many years ago when I saw a guy at a repair shop use some kind of black sealant on a tire to stop a leak between the wheel and the tire.
Old Feb 3, 2011 | 08:14 PM
RedBird's Avatar
RedBird
Originally Posted by davidv
What size wheel?
What size tire?
Wheel Size:18X8.0+20mm Front/Tire Size:245/40ZR-18
Wheel Size:18X9.0+26mm Rear/Tire Size:275/40ZR-18
Old Feb 3, 2011 | 08:18 PM
RedBird's Avatar
RedBird
Originally Posted by DavesZ#3
Define "rim fixed".
Air was leaking from the back side of the rim between the tire and the rim and took it to a shop to straighten the rim back.
Old Feb 4, 2011 | 12:23 PM
Spike100's Avatar
Spike100
Ok… I understand now.
If the repair looks good (the wheel is not bent, and you still lose air and know that the leak is at the wheel tire interface), you can use a rim/bead sealer (that is the black sealant you mention seeing in your previous posting). It’s only a temporary fix if the rim is not fully repaired.
http://www.autobarn.net/beadsealer.h...te=google_base
I use rim/bead sealer on my off-road vehicle to maintain the seal when I “air-down.” It’s a little messy. I use a power washer to clean it off the wheel rim and tire.
--Spike
Old Feb 4, 2011 | 07:52 PM
RedBird's Avatar
RedBird
Thanks Spike100
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
