WORK Wheels - New 2011 Models (6 New Wheels)
Old Feb 9, 2011 | 09:25 PM
RavSpec's Avatar
RavSpec
Vendor - Former Vendor
Default WORK Wheels - New 2011 Models (6 New Wheels)
WORK Wheels Released 6 New Model For 2011 !
Meister M1R, S1R, Gnosis HS201, HS202, Emotion 11R-FT, Varianza A6S
WORK GNOSIS HS201 and HS202
The Gnosis HS201 features a thin 12 spoke design, perfectly suited to pair with any luxury sports coupe or sedan. This wheel is offered in a large range of sizing: 19x7.5 ~ 19x11.0 (Full Reverse), 20x8.0 ~ 20x11.0 (Full Reverse), 20x8.0 ~ 20x11.5 (Step Rim), 21x8.0 ~ 21x10.5 (Step Rim). Standard bolt patterns offered are 5x112, 5x114.3, and 5x120. Custom bolt patterns available in any range between 5x108 & 5x120.65.
The Gnosis HS202 features a unique curved mesh design, which provides versatility to complement almost any vehicle. This wheel is available in 19" & 20" applications: 19x7.5 ~ 19x11.0 (Full Reverse), 20x8.0 ~ 20x11.5 (Step Rim). Standard bolt patterns offered are 5x112, 5x114.3, and 5x120. Custom bolt patterns available in any range between 5x108 & 5x120.65.
Wheels are built using 2 piece construction utilizing a low pressure cast center disk with spun forged barrel. Wheels are available in both Full Reverse barrel or Step Rim barrel. With the entire Gnosis lineup, this wheel utilizes the new redesigned lip flange. The new lip flange has a machined barrel finish along with a formed rim edge for added strength.
Due to its two piece design, you can customize offsets within 1mm increments, allowing for fine tuning of wheel fitment. In addition, two piece wheels are stiffer and suitable for track use. As one can expect with WORK Wheels, there is a wide range of widths and customization options to choose from.
WORK Meister M1R and S1R
With a completely redesigned center disk, the brand new WORK Meister S1 R brings a new generation of style while keeping the heritage of the Meister series.
The brand new WORK Meister M1 R adds a clean mesh design to the Meister series, while meeting the current demands for larger brake clearance of popular vehicles.
The WORK Meister S1 R & M1 R are both two piece construction wheels, using low pressure cast center disk with a spun forged barrel.
WORK Emotion 11R-FT
The USA Exclusive WORK Emotion 11R-FT features:
1) 18x10.5 Sizing: The 11R-FT is the first Emotion series to have a 10.5" width in the 18" sizing.
2) USA Exclusive Finishes: Matte Gray Silver (MGS) & Matte Gunmetal (MGM) are standard finishes on this Emotion 11R-FT.
3) WORK Flowforming Technology (spun forming): The key benefit for flow forming is able to reduce the barrel thickness, thus reducing the weight of the wheel without compromising the strength of the rim barrel. The 11R-FT is a good choice for motorsports racing use or at area where there are smoother roads. Unlike our competitors' flow forming wheels, WORK flow forming wheels start with low-pressure cast construction, whereas some of our competitors use lower quality gravity casting.
4) Big Brake Clearance: Due to the design of the 11R-FT, it is very brake friendly to large OEM calipers along with many aftermarket calipers.
5) Reduced Weight: By using WORK Flowforming Technology, WORK Wheels was able to save on average ~2.2 lbs. per wheel, while maintaining the engineering strength and integrity.
Old Feb 9, 2011 | 09:48 PM
kemps's Avatar
kemps
lovin the meister's
Old Feb 9, 2011 | 10:22 PM
Adon's Avatar
Adon
fck those new Meisters look too sick, super clean! if they only came in 19's or 20's
Old Feb 10, 2011 | 12:16 AM
joey77051's Avatar
joey77051
i still like the old meister better......
Old Feb 10, 2011 | 07:36 AM
AngelsVQ's Avatar
AngelsVQ
both meisters are bad ***
Old Feb 10, 2011 | 07:43 AM
350Z_Al's Avatar
350Z_Al
I have a feeling they'll be available in 19s eventually.... hopefully!
Old Feb 10, 2011 | 03:06 PM
stradaONE8's Avatar
stradaONE8
both Meisters =
Old Feb 10, 2011 | 07:29 PM
Mar48's Avatar
Mar48
damn I'll take the meisters and emotion 11Rs
Old Mar 2, 2011 | 10:13 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Any idea if I can get those Meisters in 5x120?
Old Mar 3, 2011 | 03:39 AM
RavSpec's Avatar
RavSpec
Yeah just $60 more per wheel.
Old Mar 3, 2011 | 05:09 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Miester S1R FTW! so SYCK!
Old Mar 3, 2011 | 08:16 PM
350zbehold's Avatar
350zbehold
nothing will be as og as the old meister
Old Mar 3, 2011 | 08:51 PM
Adon's Avatar
Adon
geez you old style meister lovers must really love rivets, a lot of people prefer a clean rivetless look, old meisters are great but these new meisters are now flawless
Old Mar 11, 2011 | 08:08 PM
RavSpec's Avatar
RavSpec
quick bump !
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
davidm350
Oct 31, 2015 02:28 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
Shane86
Sep 17, 2015 05:33 PM
