Bridgestone Potenza RE-11's -- what size?
Here's the update. Got them installed a couple days ago. Just breaking them in easily with highway driving. They are not nearly as slick out of the box as my T1R's were when I first put them on. Almost slid off a corner on those things. Anyway, the issue now is that I am rubbing a little front and rear. So what's the next step? Alignment with more negative camber and how much can/should I go? Roll fenders?
I am on Nismo S-Tune suspension. Pretty happy with ride quality. Considering coilovers but not sure of what brand to go with or if that would make a difference in terms of rubbing. Cost is not a huge factor. Knowledge in this area is where I am lacking.
If I can solve the rubbing with alignment or fender roll then I will leave the suspension alone for now.
Thanks in advance for input.
Thanks for the quick response. I hear it rubbing mostly in the rear when the road gets uneven as the car shifts or if I swerve back and forth I can make it rub. Sounds like it is in the rear. This morning I went over some large (wide not high) speed bumps and as the suspension compressed I heard the fronts rub and then the rears. No turning involved at that time. Hoping the rolling will fix it.
Is it a good idea to check or do the alignment anyway since I just put on new tires?
WTF, with your offsets the front should be no where close to rubbing , especially at dam near stock height. Hell i run a 255 up front on the street with a 9.5 front wheel and a lot more aggressive offset. The rear, i know is close unrolled, but rolling will easily make them clear.
your not running spacers are you?
No spacers.
I will get them rolled in the rear. If the front only rubs on speed bumps I can live with that.
If anyone has suggestions on a good place to roll fenders in Los Angeles or Ventura or Simi I would appreciate the info.
Quick update. These RE-11's are pretty blocky and seem wider than other comparably sized tires. Got the fenders rolled and problem solved.
On another note, I got an alignment and the car feels and handles great with these tires. Much better traction than the Toyo T1-R's. I highly recommend them....so far.
How are these tires for a daily driver that is not TT. I dont do auto cross or tracking. I just drive the car on the highway in Southern California (San Diego) to and from work and then cruise around the beach.
I currently have R888s and had an accident on the highway in the rain while going 50 mph. Hydroplaned and lost control. Looking for a new street tire and the RE-11 was suggested (along with the Hankook V12 Evo).
Chirag
Chirag
Chirag
Chirag
