Would 35 series profiles work on stock rears?
Old Mar 8, 2011 | 12:20 PM
highflyinkilla's Avatar
highflyinkilla
Default Would 35 series profiles work on stock rears?
I have 07 stock 18s. I can get a good deal on two 255/35/18 Bridgestone RE050As. Would this work if I move my 245/40s that are in the rear to the front. Im riding on stock suspension.
Old Mar 8, 2011 | 12:25 PM
r_seng's Avatar
r_seng
Yes, it will work.
It will look funny, mind you.
Old Mar 8, 2011 | 12:33 PM
DavesZ#3's Avatar
DavesZ#3
Almost any profile with work, the trick is in matching it to a width that produces the same approximate OD as your OEM tire was.
Old Mar 8, 2011 | 01:19 PM
highflyinkilla
I was going by the usual drop from front to rear like the stockers go from a 45 to a 40. Would this not look the about the same with 40 up front and 35 in the rear?
Old Mar 8, 2011 | 01:22 PM
Front tires are taller than rear.
Old Mar 8, 2011 | 01:26 PM
03threefiftyz's Avatar
03threefiftyz
VDC will have a strong dislike of it.
Old Mar 8, 2011 | 02:01 PM
drivessidewayz's Avatar
drivessidewayz
I dunno what stockers you have, but the OEM tire size last I checked is 225/245 45 r18
Old Mar 8, 2011 | 02:23 PM
scotts300's Avatar
scotts300
Do you have VDC? If so, it will not be happy since the front is 3/4" taller.
I have another pair of those 255 RE050As though, if you want to make 4.
Old Mar 18, 2011 | 01:45 PM
Never mind. I thought this was important. Important enough to say “thanks” or simply reply.
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Shane86
Sep 17, 2015 05:33 PM
Suffolk350z
Sep 13, 2015 02:43 PM
