Maximum Wheel Width for 2006 Z Roadster?
Old Mar 13, 2011 | 09:47 AM
BadBoi404's Avatar
BadBoi404
Question Maximum Wheel Width for 2006 Z Roadster?
I have a 2006 350Z Roadster (touring) and wanted to know:
1. What is the widest application for front wheels without modifications (including preferred offset).
2. What is the widest application for rear wheels without modifications (including preferred offset).
I see so many opinions on offsets (factory 30mm and 33mm).
3. What provides the deepest lip?
4. What provides the widest stance (closest to wheel well) ?
Thanks for any comments.
Old Mar 13, 2011 | 10:07 AM
sportbiketed's Avatar
sportbiketed
um search
Old Mar 13, 2011 | 10:29 AM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
Look through the aggressive wheels threads.
Old Mar 13, 2011 | 10:53 AM
AJCaron12's Avatar
AJCaron12
He's brand new fellas take it easy. Welcome BadBoi404. You find more info in the wheels and tires forum.
Old Mar 13, 2011 | 11:07 AM
BadBoi404's Avatar
BadBoi404
Thank you...
Old Mar 13, 2011 | 12:48 PM
Welcome. Hundreds of examples here. Look at what other members have done. Find a wheel-tire combination that you like. Copy it. No need to reinvent the wheel. (I love to say that)
Old Mar 13, 2011 | 08:25 PM
Silver350zed's Avatar
Silver350zed
i have 10.5 up front.... custom secret offset and I have 12's in the rear with a custom secret offset with a 10mm spacer.
Old Mar 14, 2011 | 12:26 PM
scotts300's Avatar
scotts300
You can fit 10.5s all around, but doubt you need to. I'd go with a standard 9-9.5" front wheel and 9.5-10.5" rear wheel and offsets in the +20 to +30 area (depending on how wide you choose in those recommended ranges).
Old Mar 19, 2011 | 09:39 PM
John H.'s Avatar
John H.
I usually run 9.5 fr and 10.5 rr. My offsets have varied. Largest tires have been 255/35 fr and 285/35 rr.
Old Mar 20, 2011 | 05:58 AM
zerafian's Avatar
zerafian
Definitely take some time to look around on the forums. The most common trend is 9.5" wide rims up front on a 245/35/19 tire and 10.5" wide rear on a 275/35/19 tire. Conservative offsets would be around +17 to +22 with around -1 to -2 camber.
though to max it out go to the aggressive/stretch tire thread. Im sure you can fit a 12" rim with a 245 tire with -6 camber.
Old Aug 26, 2011 | 05:21 PM
Did you go for the maximum coolness?
Obadabot
Jun 18, 2023 11:31 PM
