18x8 Front 18x9 Rear 35mm offset?
Old Mar 31, 2011 | 12:11 PM
makecopies's Avatar
makecopies
Question 18x8 Front 18x9 Rear 35mm offset?
Sorry I'm a Noob with this wheel stuff?
18x8 Front 18x9 Rear 35mm offset? will it look like crap?
I'm looking for flushness without spacers
Old Mar 31, 2011 | 12:26 PM
theianmcdougall's Avatar
theianmcdougall
that will sit as flush as stock rims, so deffinately not
try 18x10 18x11 Offsets from +10 to -20 depending on height, camber, tire size
Old Mar 31, 2011 | 12:34 PM
terrasmak's Avatar
Stock is 18x8 +30, http://www.1010tires.com/wheeloffsetcalculator.asp type it in and see what you will think of your new ones.
Old Mar 31, 2011 | 02:47 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Apr 4, 2011 | 01:59 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Your best bet is to find a 9.5/10.5 in the +15 to +22 offset range to be flush with the proper sized tire.
Old Apr 18, 2011 | 08:49 PM
Never mind. I thought this was important. Important enough to say “thanks” or simply reply.
Old Apr 19, 2011 | 08:37 AM
BoomerZ33's Avatar
BoomerZ33
those sizes are too close to stock. the closer to zero your offsets are the more aggressive they'll look
Old Apr 19, 2011 | 08:39 AM
TheDangerZone's Avatar
TheDangerZone
just find a 9.5/10.5 setup with low to mid +20 offset. Will fit real flush, not hella flush with good alignment. no roll needed.
Old Apr 19, 2011 | 09:15 AM
MYN1SMO's Avatar
MYN1SMO
Please stop bumping old, pointless threads for the sake of your post count.
Old Apr 20, 2011 | 07:02 AM
CTZ860's Avatar
CTZ860
With a setup like this would you want to run 275's on the front and 295's on rear? I am new at this stuff to so just seein if I got the right idea here....
Old Apr 25, 2011 | 08:27 PM
QuicksilverZ33
Im running 265/285 on a set of 18x9.5/10.5 +15 and I had to roll the rear fenders because they rubbed. I wouldn't go with a 295 unless your offset is at least +22 or higher
Old Apr 26, 2011 | 07:58 AM
Lawn Dart's Avatar
Lawn Dart
Personally, I run 245/40-18 front & 245/45-18 rear and it handles great! 275/295 is somewhat extreme. 245/275 is the most recommended size.
Obadabot
Jun 18, 2023 11:31 PM
