VOLK GTF Caliper Clearance
Old Apr 14, 2011 | 03:33 PM
joekool's Avatar
joekool
Default VOLK GTF Caliper Clearance
Hi guys just wondering if anyone here knows if the following setup will work:
Volk GTF
Front 19x9.5 +30 (+17 is too aggressive for me)
Rear 19x10.5 +24
http://www.rays-msc.com/wheels/index.cgi?d=14
http://www.rayswheels.co.jp/2009/pro...9&for=domestic
http://www.tceperformanceproducts.com/350z/g35/kits-9/
Wilwood 14" Rotors with W6a calipers..
Thanks.
Old Apr 14, 2011 | 03:56 PM
seekanddestroy's Avatar
seekanddestroy
I run GTFs 19X9.5+17 19X10.5+15 and they clear my Alliance 15" rotor 8/6 setup. Don't know if that helps at all...
Old Apr 14, 2011 | 09:59 PM
joekool's Avatar
joekool
Which columns do I use below to find offsets for the GTF wheels, there is A, B or C.. I'm confused
Old Apr 15, 2011 | 01:05 AM
joekool's Avatar
joekool
are you using spacers cause +15 would hit calipers??
Old Apr 15, 2011 | 05:00 AM
350zspl's Avatar
350zspl
+30 & +24 are weak offsets even for a 4 door
Old Apr 15, 2011 | 05:03 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
call Wilwood, get the caliper schematic, and measure against the wheel. In all liklihood, it should fit fine.
the chart is self explanatory - find your diameter and width, find your intended offset, and the caliper clearance shows up. In your case, it's an A disk, which offers the most caliper clearance
Old Apr 15, 2011 | 07:12 AM
Todd TCE's Avatar
Todd TCE
TCE Performance Products
The W6A kit requires an additional .190" of clearance over the standard BSL6 set up.
W6A:
BSL6r:
*Note the overhang difference: 1.98" vs 1.79"
The clearance needed can be viewed here:
http://www.tceperformanceproducts.com/wheel-fit/
Or the standard pdf (which includes air gap whereas the above does not) shows a spec to which you can add .190".
Here's the info:http://www.wilwood.com/PDF/DataSheets/ds547.pdf
With regard to offset choice, I would not encourage anyone to make an offset change to their wheels in order to fit a brake kit. While it's certainly possible to do the real goal is to select the proper wheel and spoke design that clears the the caliper. Changing the offset intentionally could be considered a band-aide solution leading to other issues.
Old Apr 15, 2011 | 10:16 AM
seekanddestroy
I am not running spacers. They clear fine.
Old Apr 17, 2011 | 05:29 AM
joekool's Avatar
joekool
And B disk for the rear wheels? Problem is I don't have the wheels or brake kit yet, so I'm a bit in the dark and trying to work it all out. I'd hate to buy something that doesn't fit
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
Stevo Z
Oct 3, 2015 09:14 PM
