Manually turning off Low tire pressure Light
Old Apr 17, 2011 | 12:00 PM
Peaknismoz's Avatar
Peaknismoz
Default Manually turning off Low tire pressure Light
Hi, I recently purchased this device that helps you manually turn off the low tire light.http://www.ntxtools.com/network-tool.../OTC-3831.html
Unfortunately, I can not located the plug for it under the dash. I found the DLC connector and unplug it but still cannot find the plug for the gun to connect to.
Can someone please show me pics or where its at? I look at driver side under dash.
Car=03 350z touring
Old Apr 17, 2011 | 12:08 PM
datsunHEAD's Avatar
datsunHEAD
Manually turning off Low tire pressure Light?
add air
thread/
Old Apr 17, 2011 | 12:11 PM
DavesZ#3's Avatar
DavesZ#3
I don't think that particular device does what you think it does. It appears to be nothing but a switch that makes this process...
https://my350z.com/forum/maintenance...ring-tpms.html
... a little easier. If you read that thread, you'll see that it involves grounding a connector several times. The device you're looking at appears to take the place of the jerry-rigged method.
BTW - all that does is re-register the sensors to the computer, it doesn't turn off the light for missing sensors.
Old Apr 17, 2011 | 12:21 PM
Peaknismoz's Avatar
Peaknismoz
Thanks for the help, i dont need to know all that iffy jiffy stuff. Where is the vehicle connector located behind the DLC? I can not find it. Can someone please help me find it or if my model car even have one?
liqalu04
Jan 2, 2022 12:58 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
rizzla
Sep 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
Inspatatrac
Sep 8, 2015 02:12 PM
