Spare rear tire - flashing dashboard lights?
Old Apr 14, 2011 | 04:41 PM
ot_bg_sam's Avatar
ot_bg_sam
Default Spare rear tire - flashing dashboard lights?
hello just put the spare tire on the rear right side , will fix the normal tire tommorow but all my lights are flashing on dasboard ( hand-brake , abs etc.) is that normal when you have put spare tire on your Z , thank you.
Old Apr 14, 2011 | 05:00 PM
Possible yes. Diameter of tires is different. TCS is having a fit.
Spike100's Avatar
Spike100
^^ That is because the spare tire is not the correct size for your car's electronics (VDC and TCS and ABS).
When you mount the spare tire, turn-off VDC/TCS.
--Spike
Old Apr 14, 2011 | 05:07 PM
Spike100's Avatar
Spike100
I suppose that we should describe how one does this.
You press the VDC or TCS button to disable this feature when running the spare tire (which is off-sized). When VDC or TCS is disabled, driving on the spare tire does not activate the car's electronic stability features.
--Spike
Old Apr 14, 2011 | 05:12 PM
ot_bg_sam's Avatar
ot_bg_sam
thank you so much for the reply , so its not somthn scary i was thinking wtf this things are flashing. Im new 350z owner and love my car , and i am happy I found 350z.com, from now I will be checking it every day , cheers.
Old Apr 14, 2011 | 05:18 PM
ot_bg_sam's Avatar
ot_bg_sam
I cant turn it off , it just keep flashing , but hopefully when I mount the normal tire everything will be fine .
Old Apr 14, 2011 | 06:37 PM
Spike100's Avatar
Spike100
^^ Yes... all will be fine when you mount a normal tire.
The undersized spare will defeat VDC and TCS and ABS since it is the wrong size.
--Spike
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
