19s need help on tire size
Old Apr 22, 2011 | 10:51 AM
jypeople's Avatar
jypeople
Default 19s need help on tire size
I have a set of prodrive.. 19/8.5 +22 all around.
Prob going to get 15mm spacer for the rear.
Any suggestion on what size tires i should get?
btw mine is Stock 06 Base
Thanks
Old Apr 22, 2011 | 10:54 AM
350zspl's Avatar
350zspl
without knowing what you like i can't guess what you should use, in addition to knowing if your car is lowered
i use 19 x 9.5 front 225-35-19
19 x 11 rear 245-35-19
Old Apr 22, 2011 | 11:42 AM
jypeople's Avatar
jypeople
thx 350zspl
my car is not lowered
I will keep that in mind and shop around for tires around that size
Old Apr 22, 2011 | 11:45 AM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Two questions:
Do you like stretched, straight/flat, or bulge/fat tires?
Are you wanting to maintain stock diameter/height?
Old Apr 22, 2011 | 11:47 AM
SparkleCityHop
Living in 350Z
Check these two threads and see what you like:
https://my350z.com/forum/wheels-and-...s-welcome.html
https://my350z.com/forum/wheels-and-...es-thread.html
Old Apr 22, 2011 | 12:44 PM
scotts300's Avatar
scotts300
255-265/35 front and 265/40 rear.
Old Apr 22, 2011 | 03:02 PM
You can run 225-255 mm wide. The number is possible combinations is mind boggling.
Old Apr 22, 2011 | 03:04 PM
SparkleCityHop
Living in 350Z
That's the davidv I know. (inside joke from another thread)
Old Apr 22, 2011 | 06:00 PM
terrasmak's Avatar
245/35 front and 245/40 rear
Old Apr 22, 2011 | 06:47 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Similar to stock specs = 225/40/19 front. 245/40/19 rear.
FYI - Run at least a 15mm spacer on all four corners if you plan on keeping these wheels. Otherwise, buy wheels with more appropriate specs and alleviate spacers.
Old Apr 23, 2011 | 11:41 PM
jypeople's Avatar
jypeople
thx for all the reply guys!! i will be shopping around for new tires next week thx again!!!
