tire size question!
Old May 11, 2011 | 02:44 PM
tw8715's Avatar
tw8715
Default tire size question!
right now i got 255/35/19 in front and 285/35/19 in rear
i need to replace my rear tires but what is the widest i can go?
can i put some 305/35/19 in the rears with 255/35/19 in the front?
thanks
Old May 11, 2011 | 02:47 PM
Yes you may. And if anyone says different tell them davidv said it was OK.
Old May 11, 2011 | 03:03 PM
tw8715's Avatar
tw8715
nice sounds good! time to order some 305's!
so i do have my fenders rolled and am droped about 1.2 inches. should i be free of rubbing?
Old May 11, 2011 | 03:13 PM
305/35/19 in the rears:
Actual speed 100.0 MPH. Speedometer will read 97.36 MPH. Are you OK with this?
Old May 11, 2011 | 05:48 PM
terrasmak's Avatar
305/30 is the tire you would want, before you order. What width wheel do you have? What offset is your wheel?
Old May 11, 2011 | 08:58 PM
derekinthez's Avatar
derekinthez
^what he said!
Old May 12, 2011 | 10:53 AM
tw8715's Avatar
tw8715
hmm so i am guessing i need 305/30??
this might be a dumb question but probably cant do 255/35 with 305/30 right?
Old May 12, 2011 | 11:44 AM
terrasmak's Avatar
Originally Posted by tw8715
10.5 22+
It will work, probably understeer like hell, but .........
Old May 12, 2011 | 02:46 PM
10.5 22+
Rear tire circumference is less than 1 percent greater than front tire circumference. VDC may not like this.
Old May 12, 2011 | 11:06 PM
tw8715's Avatar
tw8715
damn it! sucks that i cant fit a 305/35 in the rear without rubbing
Old May 13, 2011 | 08:10 AM
terrasmak's Avatar
305/30 is fine, then change the front to a 275/30 later.
Old May 13, 2011 | 02:49 PM
derekinthez
You will want to go wider than 255 in front, at least 265 with a 305 rear. 275 front would seem to make more sense.
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
