Meaning of "Offset for Rims"
Old Jul 8, 2011 | 09:39 PM
cphan6778's Avatar
cphan6778
Default Meaning of "Offset for Rims"
I'm thinking of upgrading to some 19's and I don't really understand what the offset means.
What does a higher number mean and a lower number mean.
19x8.0 /w 45off vs 19x8.0 /w 15off
I already tried using the search but there's over 100 post of unless thread.
Thanks in advance for sharing your knowledge with me.
Old Jul 8, 2011 | 09:55 PM
midz350's Avatar
midz350
Old Jul 8, 2011 | 09:56 PM
datsunHEAD's Avatar
datsunHEAD
inb4themob
Old Jul 8, 2011 | 10:23 PM
Offset for rims is hellaflush. You want to be rimmed up with killers system.
Old Jul 8, 2011 | 10:38 PM
ASpecTL's Avatar
ASpecTL
False.
Old Jul 8, 2011 | 11:33 PM
drivessidewayz's Avatar
drivessidewayz
fread gonna 'splode later today.
Old Jul 9, 2011 | 12:27 AM
Max-G's Avatar
Max-G
it means how cool you are.
Old Jul 9, 2011 | 12:29 AM
ZS14RR's Avatar
ZS14RR
Meaning of search.
Old Jul 9, 2011 | 12:41 AM
angelo350z's Avatar
angelo350z
Lower number means closer to your fender. Higher number means more sunk in. You did not search at all.
Old Jul 9, 2011 | 06:48 AM
BoomerZ33's Avatar
BoomerZ33
lol use advanced search
Old Jul 9, 2011 | 07:07 AM
RENFRO's Avatar
RENFRO
Old Jul 9, 2011 | 08:17 AM
verdict.'s Avatar
verdict.
The offset of a wheel is the distance from the mounting surface of the wheel to the true center-line of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true center-line of the rim (this in effect brings the tire in to the fender well more). A negative offset means the mounting surface of the wheel is behind the true center-line of the rim (this will cause the tire to stick out away from the vehicle).
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Jul 9, 2011 | 08:27 AM
D&G35's Avatar
D&G35
another way to putting this is that the lower the offsets, the bigger the lips and more it sticks out...the higher the offsets, less lippage, more sunk it is in the fender..
Old Jul 9, 2011 | 09:13 AM
dan avoN7's Avatar
dan avoN7
verdict. answered your question very well /close thread
This isn't always true, see verdict.'s post for correct definition of wheel offset. Some cast wheels are designed around a specific wheel mold so regardless of the wheels offset; the lip, spoke profile, etc.. will remain the same. Manufactures will use "hub adapters" to vary wheel specs however the wheels will look nearly identical with the exception of the center pcd.
Here's an example on the Rota Grid. The gold wheel is a 18x9.5 +38 fitment and the green wheel is a 18x9.5 +20 fitment. The wheel has the same lip size, same concave, etc.. however the center pcd is recessed further in to allow for a lower offset.
Example on the Enkei RPF1. Top is 18x9.5 +45 and the bottom is 18x9.5 +15
Old Jul 9, 2011 | 10:45 AM
D&G35's Avatar
D&G35
yeah....i forgot to mention about the face too...different faces have different concavities...thats call the disk which is important for when it comes to BBK's...just check around the site to see what people are running and don't be afraid to ask...but SEARCH is your bestfriend...
Old Jul 9, 2011 | 01:13 PM
Waiz's Avatar
Waiz
If you would have read the Top 100 thread:
https://my350z.com/forum/2003-2009-n...questions.html
Or searched for offset and found this:
https://my350z.com/forum/wheels-and-...ng-offset.html
Anywho, thanks for the help fellas.
issyz
Jul 2, 2017 03:04 PM
seagrasser
Oct 11, 2015 03:27 PM
