back end gets squirrely
Old Jul 26, 2011 | 02:05 PM
bf81350z's Avatar
bf81350z
Default back end gets squirrely
Ok, here is a newbie question. I've never owned a vehicle with this much hp/torque and my rear end just feels squirrely once i get to around 80 mph(non highway) or when I am in very hard acceleration. It is an 03' and last owner put incorrect size tires on rear (225/50/17). Is this the source of the problem or is it just my inexperience with this much power. Oh and it is a base model...no vlsd. I would appreciate any feedback. Thanks.
Old Jul 26, 2011 | 02:18 PM
terrasmak's Avatar
Could be a lot of things, the tires can do it, the tread on the tires can do it, alignment etc etc.
Old Jul 26, 2011 | 02:21 PM
John1006's Avatar
John1006
What exactly do you mean by "squirrely"? Does it feel like it's going to lose control and spin out? I dont believe that size tire would feel like that. Even though thats a good size sidewall. Is there any tread left on the tires?
Old Jul 26, 2011 | 02:23 PM
bf81350z's Avatar
bf81350z
the car feels %100 sound and tight at low to moderate speeds. With that being said would alignment still be an option. Would a slight misalignment present itself only at very high speeds. The tires are new, yet diff brand up front then in back. My gut is that the combo of mismatched tires and incorrect rear tire size is to blame.
Old Jul 26, 2011 | 02:27 PM
bf81350z's Avatar
bf81350z
By "squirrely" i mean that it seems as if one or both tires loses traction and back end seems to break loose and go in the opposite direction as front end...creating a kinda fishtail.
Old Jul 26, 2011 | 02:29 PM
bf81350z's Avatar
bf81350z
hard breaking in response to the squirrely feeling seems to compound the situation. I guess i'm kinda answering my own question. All points toward mis alignment...any ideas?
Old Jul 26, 2011 | 02:37 PM
DavesZ#3's Avatar
DavesZ#3
1) 03 models had a harder suspension than all others. Revised suspension offered a softer ride. That harshness may partially explain your observation.
2) Smaller than recommended tires will definitely reduce traction.
3) Over inflated tires. Hard rubber compound. Worn or damaged suspension parts could all be factors.
4) Learn to throttle back a bit. "Hard" acceleration doesn't belong on the street. Otherwise your next thread may have the subject "I just wrecked my Z".
Old Jul 26, 2011 | 02:44 PM
mattleegee's Avatar
mattleegee
i think i may have the same situation as you, after reading for awhile people noted 03-04 models having "feathering" issues, and some had good results with alignments, those people also said the place they went "knew what they were doing" as alot of alignments shops didnt understand the problem
i get most of mine at highway speeds, and during engine braking, during acceleration i do not notice it at all, and the brakes i do notice it also
Old Jul 26, 2011 | 02:58 PM
Max-G's Avatar
Max-G
alignment.
Old Jul 26, 2011 | 03:23 PM
drivessidewayz's Avatar
drivessidewayz
Old Jul 26, 2011 | 04:02 PM
bf81350z's Avatar
bf81350z
I understand keeping track driving to the track, but i'm trying to identify any underlying factors that could cause problems on a general level. i'm just trying to understand how the car "should" feel/react when properly tuned.
Old Jul 26, 2011 | 04:05 PM
bf81350z's Avatar
bf81350z
as my wheels are not properly staggered per factory specs....just want to know if this leads to poor traction and the loose feeling or my car is not properly aligned.
Old Jul 26, 2011 | 04:59 PM
Welcome. Horsepower and torque are relative. You will get accustomed. Not certain what size wheel you are running. May go with a wider tire. Or a better tire.
Old Jul 26, 2011 | 08:25 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
yes
yes
this too
alignment
this
Old Jul 27, 2011 | 02:45 AM
winchman's Avatar
winchman
Have you checked your tire pressures lately?
Old Jul 27, 2011 | 08:30 AM
bmccann101's Avatar
bmccann101
squirrely at 80+ equals too much toe in rear, get rear camber arm and toe delete botl, good alignment, and youre done.
Also, check your front CLA and compression rod bushing.
Replace all for 500-650 and you will have an absolutley solid new car feel while driving.
Old Jul 27, 2011 | 09:56 AM
abarclay's Avatar
abarclay
Pleask
Dec 21, 2021 03:17 PM
apex locator
Jul 23, 2021 02:27 AM
pr_350z
Oct 1, 2015 05:03 PM
Depravity
Oct 1, 2015 04:49 PM
