Tire package work with VDC???
Old Sep 7, 2011 | 06:07 AM
Gmadole89's Avatar
Gmadole89
Default Tire package work with VDC???
I'm looking to pick up this rim and tire package. Can't figure out if these dimensions will work within the VDC tolerances.
http://www.wheelfire.com/scontent/Wh...727&CheckFit=1
19 in. Rims
Front: 19x8.5
Rear: 19x9.5
Tires
Front: 235/35/19
Rear: 265/30/19
Old Sep 7, 2011 | 07:12 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Your rear tires will be shorter than your fronts. A 255/35/19 in the rear will work.
Old Sep 7, 2011 | 08:22 AM
terrasmak's Avatar
The common tire for your setup would be 245/35 front and 275/35 rears.
Old Sep 7, 2011 | 09:03 AM
Gmadole89's Avatar
Gmadole89
Thanks guys, so you suggest picking up the rims and tires separate so I can control the sizes?
Old Sep 7, 2011 | 10:22 AM
bmccann101's Avatar
bmccann101
request a diff size in your package.
pretty simple.
Old Sep 7, 2011 | 10:41 AM
Gmadole89's Avatar
Gmadole89
Sorry didn't realize they would do that. So the 255/35/19 in the read will make that package work?
Old Sep 7, 2011 | 12:08 PM
terrasmak's Avatar
I wouldn't , to short for a rear tire. 255/35 is a common front tire when combined with 275/35 rear.
You want 245/35 or 255/35 front and 275/35 rears.
Old Sep 7, 2011 | 12:12 PM
Gmadole89's Avatar
Gmadole89
Thank you just the answer I was looking for. Those tire sizes the 245 fronts and 275 rears with the 19 in. rims will still allow the VDC to function properly?
Old Sep 7, 2011 | 12:17 PM
terrasmak's Avatar
Thank you just the answer I was looking for. Those tire sizes the 245 fronts and 275 rears will still allow the VDC to function properly?
I wouldn't have suggested them if they wearn't the proper ones for the car. Yes the will work, and they are the same tire height as stock.
Old Sep 7, 2011 | 12:26 PM
AdvanZ33's Avatar
AdvanZ33
Either option will make your VDC happy. Assuming you are using a 235/35 in the front, 255/35 is just my personal preference because I don't like to use "fat" tires. 235mm=9.25" 255=10"
Additionally, on the 235/255 set up the rears are 7mm higher than the fronts (happy VDC) and, for example, the OEM V1 touring wheels the rears are 9mm higher.
Explore your tire options and prices. Some sizes are more easily obtained than others and sometimes cheaper.
Old Sep 7, 2011 | 12:29 PM
AdvanZ33's Avatar
AdvanZ33
Something else to keep in mind if you don't plan on lowering your car.
Old Sep 7, 2011 | 12:36 PM
Gmadole89's Avatar
Gmadole89
Thanks everyone. Very good info. Appreciate it all. Sorry of I'm being repetitive but I'm new to the forum and trying to learn as I ago. Thanks again!
Old Sep 7, 2011 | 01:17 PM
265/30/19: Actual speed 100.0 MPH. Speedometer will read 105.63 MPH. Do not like this choice.
Old Sep 8, 2011 | 10:32 AM
350Vshot's Avatar
350Vshot
look up miata tire calculator on google. 245 35 fronts and 275 35 rears. It will look perfect
aarrgghh
May 1, 2022 11:04 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
hardkicks
Sep 20, 2015 12:28 PM
Shane86
Sep 17, 2015 05:33 PM
