Need Help Choosing Wheels
Old Sep 21, 2011 | 11:40 PM
ronn1's Avatar
ronn1
Default Need Help Choosing Wheels
Ok..I need two simple questions answered..
I found a square set of new 18X9 TSW wheels DIRT cheap
and they are advertised as a *Mustang* fitment.
1)) These are advertised as *Mustang wheels*, but they have the same bolt pattern as the Z and the offset is 35, so they're very close to my OEMs which are 30 front and 33 rear. I also plan on using my current 15MM spacer, so I should be good to go????
2)Do TSW wheels have the *pockets* (spaces between lug holes) on the hub mounting surface to accommodate extended spacer studs? This isn't a deal breaker..I can cut em down.
Just need confirmation on this
Thanks..
Last edited by ronn1; Sep 22, 2011 at 11:12 PM. Reason: Wrong wheel name in title!
Old Sep 22, 2011 | 12:19 AM
callmepapichulo's Avatar
callmepapichulo
keep your stock wheels
Old Sep 22, 2011 | 01:01 AM
ronn1's Avatar
ronn1
That doesn't address my question.
BTW..here's what they look like on the car in hyperblack..the color I'm looking at. Would you believe $525 SHIPPED?
I found this pic here..same size (diam wise)and color... same car color too.
Old Sep 22, 2011 | 04:21 AM
Looch's Avatar
Looch
Yep, I'd still keep the stock wheels
Old Sep 22, 2011 | 05:14 AM
bmccann101's Avatar
bmccann101
525 shipped is not a deal at all man.
Axis are marginally better and quite a bit lighter.. i bought a set of Axis VIP 20 8.5 20 9.5 for that price brand new shipped.
Old Sep 22, 2011 | 06:08 AM
Spork's Avatar
Spork
Keep the stock wheels, IMO.
For these wheels, yes.
Old Sep 22, 2011 | 06:24 AM
terrasmak's Avatar
$525 more for I nice set of wheels if you don't buy them.
Old Sep 22, 2011 | 06:26 AM
AroundMyHorn's Avatar
AroundMyHorn
The widths and offset are no bueno man. Keep looking.
Old Sep 22, 2011 | 07:53 AM
scotts300's Avatar
scotts300
What is the center bore? Bolt pattern is one thing, but center bore needs to fit, too!
Old Sep 22, 2011 | 11:15 AM
ronn1's Avatar
ronn1
You realize that' for the SET of FOUR here?
Old Sep 22, 2011 | 11:18 AM
ronn1's Avatar
ronn1
UH...just use hub centric adaptor ring that comes with all aftermarket wheels to fit your car. This set is a typical 73+ bore..so ya just get an adaptor ring that's 73/61.1
Old Sep 22, 2011 | 11:23 AM
bmccann101's Avatar
bmccann101
yes.
what model are they.
if they are the brand new series like snettertons then its a good deal, i bet you they are thruxtons or kayalamis tho.
heres a set in 20 inch.. 595 plus 200 shipping . some ppl are crack smokers and sell them for 1200 bucks.. thats not the going rate tho man.
ronn1's Avatar
ronn1
Why is this offset a problem? They're within 5mm front and 2 mm rear? I bet these can be used without 15mm spacer. Do you have specific info on why they won't fit with this offset? I'm open to HARD DATA! Without spacers and 9" I calculate that they will be 17mm more inboard up front and 8mm more inboard in the rear. Does anyone here know if that would interfere with suspension in that case? Of course the 15mm spacer would move them way back out with no problems.
Old Sep 22, 2011 | 11:28 AM
AroundMyHorn
I'm not talking them interfering, I'm talking about them looking chitty from being sunken in too much. Hellasunk approved!
Old Sep 22, 2011 | 11:35 AM
ronn1's Avatar
ronn1
They will actually stick out a tad farther than my stock set up now! I'm switching to 9s...so taking new offset into consideration, they will STILL stick OUT 7mm further up front and 4mm farther out in the rear. That's not flush for sure, but it's MORE flush that stock now. That's WITHOUT the 15mm spacers I plan to put on
Old Sep 22, 2011 | 11:43 AM
ronn1's Avatar
ronn1
yes.
They are BRAND NEW Mondellos which are prolly discontinued (older) now..see new pic I put up. I want to stay with 18s.
Old Sep 22, 2011 | 11:52 AM
Waiz's Avatar
Waiz
1) These wheels have been around forever, plenty of threads on them
2) The ones you posted are not the Thruxton
3) I had them prior, $525 is not a deal it's basically their going rate.
4) I don't recall if they had pockets in the back of the wheels.
5) 18x9 +35 is fine (but not very aggressive at all and not worth it IMO)
6) I would keep your stock wheels and get spacers rather than Thruxtons. They are very heavy wheels and my car felt sluggish with them on.
Old Sep 22, 2011 | 12:10 PM
ronn1's Avatar
ronn1
Thanks..they're MONDELLO. I just got 15mm spacers for my stock wheels. What I was thinking>>>If I got these..I would leave those spacers on.
Anway..my other choice (for $700 more shipped though) are the ROTA Torques:
18X9.5 all around.. 28MM offset wil stick out far enough for my taste since they're 9.5.
Old Sep 22, 2011 | 01:18 PM
Neimad's Avatar
Neimad
The price on the Rotas is really close to Enkei Rxxx pricing. I'd find some used LMGT4s or G35 Ray's if I was trying to save money.
Old Sep 22, 2011 | 09:35 PM
jasabeast's Avatar
jasabeast
Ill sell you some Work XD9's.. lol
