Advice on wheels.....17" front and 18" rear?
Old Oct 7, 2011 | 02:12 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Default Advice on wheels.....17" front and 18" rear?
Would this be a bad idea?
Enkie RPF1
17x10+18 front and 18x10.5+15 rear????
Some stock wheels come with 18 front and 19 rear, so why not do the above? I have had the RPF1's before win 18's all around and I have had 17" FN01RC's. So why not mix it up? Would it look stupid? What tire size would I go with? 285/35 or 295/35 rear is a must, but what about the front?
Reason I ask... Just picked up a pair of 18x10.5+15 at a decent deal in silver. But... the 9.5+15's are backordered for forever it seems. No one has them that I have called.
Old Oct 7, 2011 | 02:30 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
I dont see where it would be a bad idea. I personally don't think it'll look that great but if you can clear the brakes... Why not try it.
Old Oct 7, 2011 | 02:36 PM
MyV6IsFast3r
That's what I was a little worried about.... Stock Brembos so it will all clear, just don't want it to look too stupid. Just wondering how I would do the tires to get max grip and not look all goofy.
Old Oct 7, 2011 | 02:49 PM
Waiz's Avatar
Waiz
I'm guessing this isn't for a 370z?
The Nismo RS Concept runs 17" front 18" rear but is slammed..
Old Oct 7, 2011 | 02:51 PM
Flo-ridaZ33
I'm sure if you use the right tire profile it'll look fine. As long as they're functional.
Old Oct 7, 2011 | 02:56 PM
MyV6IsFast3r
Waizzz - Im a noob, should be in the 350z wheel forum. My BADDDDD.....
Yes, it's all going for function.
Old Oct 7, 2011 | 04:51 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I think running 2 different light weight wheels on the street says:
a) I drift to the store and back
b) I can't afford 4 of the same wheel
Not that I don't think you can afford them but it seems like a setup you would normally see on a boi racer S13 or a track car.
Old Oct 7, 2011 | 07:04 PM
terrasmak's Avatar
275/40-17 would be the proper front tire
Old Oct 7, 2011 | 07:45 PM
singh's Avatar
singh
_______________
you're gonna have to get pretty low to pull off that 17in look.. i say go for it
Old Oct 7, 2011 | 08:51 PM
Considering that you are a 7 year member you know that this combination will be fine. Its tire height that matters- not wheel diameter.
295/35x18: Actual speed 100.0 MPH. Speedometer will read 102.11 MPH. THis is acceptable.
Do you have VDC?
Old Oct 9, 2011 | 06:31 PM
MyV6IsFast3r
It's the same wheel doofis, just a different size up front.
Davidv - I know it will work just fine. More worried about it looking retarded with a slightly larger sidewall in the front than rear. But I think I found some 18's for the front too. They were backordered till Dec something and im just being impatient, but I think I found some.
Old Oct 9, 2011 | 08:30 PM
ronn1's Avatar
ronn1
Enkie RPF1
Here's some pics 17s front 18s rear:
Looks good to me.
Old Oct 9, 2011 | 08:56 PM
sdZ33's Avatar
sdZ33
I used to run a 17x9 front and 18x9.5 rear for a while... I ran a 245/45/17 and 275/40/18 and it looked pretty good... I'll see if I can find a pic
Old Oct 10, 2011 | 05:27 PM
Spike100's Avatar
Spike100
17” front wheels with 18” rear wheels provides a great handling 350Z with good ride comfort. Personally I think it’s a better setup than 18" front wheels with 19” rear wheels.
--Spike
Old Oct 26, 2011 | 06:50 PM
mr. sparco's Avatar
mr. sparco
Bump this thread since I'm about to do the same. OP post pics if you installed the rims.
Old Oct 26, 2011 | 07:38 PM
Voboy's Avatar
Voboy
Nismo LM GT4 wheels 17x9.5 (front) and 18x10.5 (rear); Advan A048 tires 255/40R17 (front) and 265/35R18 (rear)
Read more: http://www.superstreetonline.com/fea...#ixzz1bxDKYU7b
http://www.superstreetonline.com/fea...t/viewall.html
Old Oct 26, 2011 | 07:48 PM
KingBaby's Avatar
KingBaby
Hardest Setting
check out the weight saving on just rims
then
check out the money saving on just tires
then go out and buy a set!
If I was stateside I'd be snacking up a used set of rpf1s in seconds...
Old Oct 26, 2011 | 10:13 PM
MyV6IsFast3r
I just went with 18' all around. 17's were basically the same price.
Old Oct 26, 2011 | 11:42 PM
terrasmak's Avatar
Not even close, tires are almost $100 a tire cheaper for 17's when you are dealing with sticky street or R comps. I would still have the 17/18 combo if RPF1's in 17 fit over my front calipers.
Old Oct 27, 2011 | 05:59 AM
Voboy's Avatar
Voboy
What are you running now? (brakes)
