Axis Se7en Mod 20x10/20x9 Wheel Weights/Info w/ Toyo T1S's
Old Dec 19, 2003 | 04:13 PM
jeffrey's Avatar
jeffrey
Default Axis Se7en Mod 20x10/20x9 Wheel Weights/Info w/ Toyo T1S's
Just as an FYI I weighed my new wheels before I mounted them. I have one of those nifty digital fishing hanging scales (not for fishing; for mountaineering/backpacking, I use it to weigh my packs).
The weights:
Front: Axis Se7en Mod 20x9 w/ Toyo 245/35/20 - 46lbs on the nose. 3.46% larger in circumference (2134mm vs 2063mm).
Rear: Axis Se7en Mod 20x10 w/ Toyo 275/30/20 - 53.1lbs. 0.93% larger in circumference (2114.3mm vs 2094mm).
I figure maybe we could start up an aftermarket wheel weight list? Might be kinda helpful.
Stock wheel w/ tire weights: (according to wheel weight found on 350zmotoring.com and tire weight from Bridgestone.com; I'll weigh my actual wheels when I change them):
Front : 51.25lbs
Rear: 53.15lbs
So it looks like it's a wash in the rear and I'm losing about 5lbs up front.
This is all just for informational purposes, maybe Victor can start up a sticky thread.
Old Nov 8, 2006 | 12:40 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Very very old thread being revived.
I searched for almost an hour and finally found out the approximate weight of 20" Axis Seven Mods with Tires. Might be helpful to anyone else.
bcoffee20
Nov 19, 2015 06:39 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
jeffrey
May 7, 2005 06:07 PM
Vlad
Mar 30, 2004 06:50 AM
J Ritt
May 18, 2003 06:29 PM
