17" stock -->> 18" Nismos
Old Dec 28, 2003 | 12:49 PM
BluZee's Avatar
BluZee
Default 17" stock -->> 18" Nismos
This is for anyone that has gone from the 17" stock wheels to the 18" Nismos. Is there a noticable difference in ride quality and/or handling? Is the offset of the Nismos the same as the 17s? Im new to the site and couldnt really find any answers anywhere else. Thanks for the help. BTW, any other thoughts are appreciated also.
Old Dec 28, 2003 | 01:02 PM
fisherprice's Avatar
fisherprice
I have been around for a while. I am thinking of doing the same. I would really like the tires to be flush with the body.
Old Dec 28, 2003 | 01:32 PM
ZIABLO's Avatar
ZIABLO
I am Batman
I'm doing the switch now. I can tell you this much, the handling will be much better due to the tires I'm putting on: Goodyear Eagle F1 GS D3. I didn't really feel safe in the stock Potenzas. Also, the tires are wider.
Old Dec 28, 2003 | 01:37 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
If your using the correct size tires 245/40-18 and 275/40-18 you will be very pleased with the end result. Ride quality is unaffected and they will sit out to the end of the fender far enough without rubbing.
Old Dec 28, 2003 | 06:12 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
to give you an example.. I had 18" stock wheels...
putting on the 18" LMGT4's made a HUGE difference in traction and handling...
Old Dec 28, 2003 | 06:17 PM
lowrider's Avatar
lowrider
With the right tires, it's a great mod. I put on Dunlop SP9000s (245/40 and 275/40). The off sets are +25mm front and +30mm rear, which in my mind is perfect.
Lou
Old Dec 28, 2003 | 07:35 PM
Drumtemp's Avatar
Drumtemp
Default Re: 17" stock -->> 18" Nismos
The ride IMO is better. I like the stability of the wider tires over stock. I went from the stock 17's to the Nismos. The offset is different for the two: Stock (17's) is 30mm front and 33mm rear, I believe. As mentioned, the Nismo's are 25mm front & 30mm rear. The only areas where the tires peek out from the body is where the fender wells curve inward. Otherwise, the tires are just a bit inward of flush to the outer most part of the fenders.
Also, as a plug for the Goodyear F1 GS-D3 tires: I've been caught in two down pours of rain so far since putting on the tires, and the feel from the road is as though the Goodyears don't even realize the road is wet--they stick as if it were dry! I'm sold!
Old Dec 29, 2003 | 05:46 AM
BluZee's Avatar
BluZee
Thanks for all the help guys. Another thing I just thought of is what tire pressure are you suppose to run with the Nismo wheels?
Old Dec 29, 2003 | 07:05 AM
ChinaClipper's Avatar
ChinaClipper
Per the instructions packaged with the Nismo wheels that specify the correct (or recommended) tire size, also comes recommendations to run the OEM tire pressures. If you follow the included directions, you cannot go wrong!
Old Dec 29, 2003 | 07:17 AM
lowrider's Avatar
lowrider
ChinaClipper
your instructions are almost correct. They are correct if going from an 18" wheel. If coming a 17" wheel it says to run 34PSI front and rear, and in another section it says to run 35lbs front and rear. I believe 35PSI to be correct.
Lou
Old Dec 29, 2003 | 07:25 AM
ChinaClipper
Originally posted by lowrider
ChinaClipper
Lou
Roger that Lou! 35 psi is the correct pressure. Those Nismo wheels look sweet on your G!
Old Dec 29, 2003 | 11:30 AM
lascala26's Avatar
lascala26
Will the tire pressure monitors work with the Nismo 18" wheels and the Goodyear tires? How much do the Goodyear's run ($) per tire...rear? Thanks!
Old Dec 29, 2003 | 12:07 PM
Jason@Performance
Performance Nissan
yes the OE Tire Pressur Monitors work with the NISMO WHeels...
Old Dec 29, 2003 | 04:03 PM
Dissolved's Avatar
Dissolved
Wow your Z looks great Konvertor. Wheels look good. Looks better than Jeff's
Just kidding Jeff
Old Dec 29, 2003 | 04:11 PM
Dream2Reality's Avatar
Dream2Reality
Are there 19" nismo rims out now? That'd be hot
Old Dec 29, 2003 | 06:51 PM
Drumtemp's Avatar
Drumtemp
Check out Tire Rack, or Discount Tire (America's Tire). I purchased mine from Discount Tire--cost more, but included mounting and balancing. I believe fronts were ~$214ea and $270ea for the rears.
Old Dec 30, 2003 | 06:42 AM
ZIABLO's Avatar
ZIABLO
I am Batman
my fronts were about 200 each. rear about 250 each. (tirerack)
Old Jan 1, 2004 | 01:04 AM
ctwentytwo's Avatar
ctwentytwo
In Japan they are. I asked about them from performance nissan as well as courtesy nissan, and both said they are not available domestically... as of yet. That pic below is the 19 in. LMGT4... just click the image.
Old Jan 1, 2004 | 05:27 AM
FairladyZ's Avatar
FairladyZ
I know gruppe-s had a few sets (19's) a few months back. I believe they can get them though.
Old Jan 1, 2004 | 07:20 PM
lawnmore's Avatar
lawnmore
Jeff; I have an 04 touring coupe -auto with stock 17s. I am considering 04 g35 coupe 18inch wheels and tires,225/45R18-245/45R18, is there any problems with this set up? ie speedo or computer issues, etc etc.Thanks
