Track Enkei Raijin 18x9.5 and RS-3
Cant fine the answers, i searched and found this thread but questions still un-answered.
http://g35driver.com/forums/wheels-t...ire-sizes.html
I want to know what the best size tire to run on 18x9.5 for front for track..
Im getting rid of my 19x10 +35 with 265/30 ad 295/30 Hankook evo v12s for some 18" wheels to make it cheaper for better quality tires. I do find with this current set up when turning tightly the front end feels like it skipps.. not sure if thats due to the profile or too heavy and wide on front??
I have regular canyon runs and getting into fun track days more often
whiteline sway bar on soft both front and rear
bc racing BR series coilovers on +12 front and rear
usually run 36psi cold
and just got ap racing 3700 and 3750 BBK
So with that info i am getting Enkei Raijin 18x9.5 +15 for rear and will use RS-3 285/35/18
front i am unsure and need help...
1. what size rim 18x9.5 or 8.5 + 35
2. what size tire, 245/255/265 and what profile, 35 or 40 ?
- people have different opinions, go smallest size of tire for the rim for better turn in (less skip?) and then others say wider = more stable....
Ideas?
Ideas?
265/40/18 all four corners mounted on that 9.5+35 wheel so you can rotate and replace without worry.
Last edited by Amirs350z; Apr 9, 2012 at 06:52 AM. Reason: Saw it was an 18" wheel
The RS3 runs large, so I'd go 265 all around as well. I have the 285 RS3s on 9.5s all around, and although it seems to 'work' just fine, I do think the 265 would be a better fit. If you go 10.5s all around, then i'd go 285 tires all around.
285/35 i got a set new but from a guy taht brought them last year and didnt use them, cost us here in Au, $350e fitted but got them for $200 each (+$15e to fit) .. so if i go 285/35 this time and then 265/40 in front and when i need new tires just get 265/40 all round ?
is there much of a difference between the 35 and 40 if i cant get the 40s?
And too bad i cant fit +15 9.5 in the front as i love the deep concave look..
Thanks for the info.
Here's what I got back from Enkei:
"They will definitely clear the ap racing 3700 brakes all the way around. 18x9.5 +15 is NOT nice for the fenders up front though. He will be pulling and rolling fenders.
If he wants 18x9.5 all the way around, why not do the 18x9.5 +35 up front and then the 18x9.5 +15 in the rear. It will still clear the calipers and he won't have to screw with the front fenders."
Oh great !!! I have a G35 Coupe, not 350z but both the same.?
Im getting 265/35 and 285/35 RS-3, found 2 good deals on new tires from private sales so savings heaps and lucky i got right sizes
anyone got any pic of the wheel turned? under heavy load and sharp corners i would be fine? / track use.. ?
Raijin only come as large as 9.5 and i dont like the look of RPF-1..
Wait, when you said:
were you talking about tire sidewall or offset?
If it's offset, you'll want the +15. a wider track means the distance, fore and aft, between two wheels - or driver/passenger.
Well 30 means more room so good news!
yes i want +15 all round, and thanks i understand the wider track now,
greater the offset the closer the wheels are L to R.. , the less (+15..) the further away from each other
So having them further away is better for stability and quick tight cornering?
will post pics up in few weeks once i got them all on the car !!!!
Cant wait, should be just in time for track day
P.S what toe and camber should i get alignment guy to do ? im stock camber arms, only lowered a little with coilovers.. still 100mm from bottom of car to road
Mmm I don't know about quicker turn in as I'm not too familiar with all the dynamics of changing width, suspension and tire compound on the car just yet. Hopefully I'll be learning more during this track season.
ok looking at this calculator
http://www.rimsntires.com/specs.jsp
it says the 9.5 +15 will stick out 15mm more than my current setup, looking at this pic it is pretty much dead on flush with the lip...
so the front since is not too low you think will be fine still? i run it at +12 dampening ...
Rear has a bit more room, ill measure tomorrow, i think its 10mm
Not bad... i like it better but not the right colour.. i like the GTC-01 but too $$$
Thats why the Raijin was perfect, good price, right design, right colour..
too bad its not in 10.5 but i think 9.5 will still work
any idea on the above terra? others run 9.5+15 but must use camber arms or camber like crazy to fit... i dont have camber arms nor wish to get them..
stay with +35 which = same as i got now, or take the risk with +15 and not lower it any further ? im worried about hard cornering which i do every day.. i just love roundabouts, empty T-sections and no VDC
Just do the +15 up front with a 265/35 to be safe. Then run a 275/35 or 285/35 out back.
I highly suggest camber arms, the added camber makes the car handle so much better. Tire life will also improve with more front camber, if your doing a lot of corner turning.
whats a good value for money camber arms and what amount would i need? toe also ? (like bc racing coil overs, you can get alot better (tein) but for the money the BC are great..) Hardrace ones ? http://justjap.com/store/product.php...61&cat=&page=1
How the f*&k did you fit that in !!? side view and you running camber arms?
