Splined Lug Nuts. Dumb Question.
Old May 14, 2012 | 01:43 PM
N80's Avatar
N80
Default Splined Lug Nuts. Dumb Question.
I did do a search. Did not find the answer, probably because it is so dumb no one has ever asked it.
I just got a set of RPF1s. Will get long, open ended lug nuts since I'll probably get some ARP studs in the future.
Many of the ones I see, particularly Muteki, are splined. So here is the question: Can they be taken on/off with anything but the splined socket that is included? I'm just wondering because I know that if it is the only tool that will work I will lose it or it will roll down a storm drain, etc etc at the worst possible moment. I guess I could buy several of them, but if the splined nuts will only work with a splined socket, then I'll keep searching for a hex nuts.
Old May 14, 2012 | 02:42 PM
datsunHEAD's Avatar
datsunHEAD
i think it only works with those but there so abundant you could go to any tire shop and pick one up for a few bucks but there are other ways to bust them lugs or locks off off if you ever lost the key
Old May 14, 2012 | 04:12 PM
albinobob's Avatar
albinobob
They're like 5 bucks a pop at discount tire I have 6.
Old May 14, 2012 | 04:30 PM
Waiz's Avatar
Waiz
OP you're over-thinking things.
If you lose the socket you can just buy a gator grip to take it off instead
Old May 14, 2012 | 05:14 PM
Can a safe cracker open a safe without the combination?
Old May 14, 2012 | 05:17 PM
N80's Avatar
N80
That is correct.
Old May 14, 2012 | 05:22 PM
Spork's Avatar
Spork
Spline drive lug nuts need the spline socket. I have a set of blue steel Gorilla spline lug nuts. I wouldn't go for any of the cheaper, aluminum ones. The tiny "weight savings" is mostly a marketing gimmick and doesn't offer sh*t in terms of performance.
Old May 14, 2012 | 05:27 PM
N80's Avatar
N80
You're right, but if the splined sockets are as easy to come by as everyone says then the combination would be 1-2-3-4.
But that brings up a question. Are the splined nuts purely for security? I assumed they were just a superior form of socket. If it is purely for security then I don't need them anyway. These will only be on at the track.
Old May 14, 2012 | 05:34 PM
Italianjoe1's Avatar
Italianjoe1
They are also smaller diameter, makes them easier to fit in most aftermarket wheels.
Old May 14, 2012 | 05:52 PM
ronn1's Avatar
ronn1
This is true of EXTERNAL splines (on the outside), since there are tons of these lug nuts out there. I have open ended INTERNAL splines and there aren't many of these on wheels...so not many keys for these around. Not as good as a locking system, but still a deterent to theft.
Old May 14, 2012 | 05:54 PM
ronn1's Avatar
ronn1
Will that fit into *tuner sized* wheels? Doesn't look like it
Old May 14, 2012 | 10:35 PM
Waiz's Avatar
Waiz
That particular one obviously does not, the photo was used as an example. They come in a variety of sizes.
Also OP, you can order specific sockets from Gorilla directly that are thin-walled and padded
http://www.gorilla-auto.com/thin-wall-sockets
Old May 15, 2012 | 11:16 AM
N80's Avatar
N80
Cool. Thanks.
Old May 16, 2012 | 01:43 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
This is actually really awesome, never knew about this product! Thanks for posting this up.
Old May 16, 2012 | 04:42 PM
Waiz's Avatar
Waiz
I aim to please
Depravity
Oct 1, 2015 04:49 PM
Alexreyes
Sep 30, 2015 11:30 PM
