35th anniversary aftermarket center caps?
Old May 14, 2012 | 06:01 PM
shadoweclipse's Avatar
shadoweclipse
Default 35th anniversary aftermarket center caps?
Does anyone know if there are any aftermarket center caps that fit the 350z 35th anniversary wheels? I am having a hard time finding ones that fit right.
Any help is greatly appreciated.
Old May 14, 2012 | 07:51 PM
TwoFastFurYa's Avatar
TwoFastFurYa
I've always wondered.....What are the differences between the 35th Anniversary and the OEM 06+ Wheels anways?
Old May 14, 2012 | 10:43 PM
Waiz's Avatar
Waiz
Uhhh, I'm afraid to ask why you want to put aftermarket center caps on your stock wheels.
I don't know of any that work nor would I recommend it without it looking tacky.
I believe there is a slight color variation in the 35th, otherwise they are the exact same wheel
Old May 15, 2012 | 03:30 AM
shadoweclipse
Well the reason I want aftermarket ones is because I want to try to find a cap with just a plain surface. Reason doing so is because they are not on a Nissan, they are on my 2010 eclipse. I liked the look of the wheel plus i needed a wheel to clear my Brembos. Right now i have the center cap wrapped in cf vinyl and it looked good covering Nissan and all but im afraid it won't survive the winter.
So even if someone knew the size of it. I think it's 53mm for the face but then the secondary sizes of the cap in the back to be able to pop into place.
Old May 15, 2012 | 04:14 AM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Go buy a digital caliper and measure the inside of the mounting hole. That will tell you what size mounting ring you need on the back side of the center cap.
350z82
Oct 1, 2015 06:25 PM
