Michelin tires run true size?
Old Jan 11, 2013 | 12:05 AM
JDMStanced's Avatar
JDMStanced
Default Michelin tires run true size?
hi, i'm looking at these used michelin tires but they are 235, not 225. But i really need 225 for fitment.
Do Michelin ps2, and Michelin pilot super sport cup run small or true size?
thanks
Old Jan 11, 2013 | 10:18 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
I believe Michelin Pilot Sport PS2s and Michelin Pilot Super Sports actually run wide.
Old Jan 11, 2013 | 11:14 AM
neal@tirerack's Avatar
neal@tirerack
We have not seen any come in smaller or larger than what the actual size states.
Old Jan 11, 2013 | 11:20 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
My 305s have a blocker shoulder than hankook 305.
Old Jan 11, 2013 | 11:37 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I ran PS2s once and I remember them being on the smaller/thinner side. FloridaZ33 had them on his purple TE37s, I think he had 255/35 285/35 on 9.5/10.5" wide wheels. Check out his build thread.
Old Jan 11, 2013 | 12:12 PM
Spike100's Avatar
Spike100
Just curious... Why do you say "But i really need 225 for fitment."?
235's with the correct profile will fit. I'm running 245's on my front stock (8") wheels.
--Spike
thanks
Old Jan 11, 2013 | 02:22 PM
mrbriandoucette's Avatar
mrbriandoucette
Agree, 235 should fit with the right profile. You can try one of the online tire sites and use their search by vehicle function to get a good idea on those tires and see if they will fit. TireTeam.com is one of them.
Old Jan 11, 2013 | 02:23 PM
JDMStanced's Avatar
JDMStanced
thanks guys,
my tires are pretty close to the fender, so having wider tires would have contact with the fender.
Old Jan 11, 2013 | 03:10 PM
Spike100's Avatar
Spike100
^^ You do not have wide tires. In fact and for the Z, you could consider these tires as moderate width.
If you are close to rubbing with these tires, you either have a crazy offset on your wheels (not likely) or spacers (again not likely with 255 mm tires).
Something is not right here. We need more details to provide good help.
What is the wheels' offset (front and rear)?
--Spike
Old Jan 11, 2013 | 03:29 PM
DavesZ#3's Avatar
DavesZ#3
All tires runs slightly different sizes. Example - the first set of PS2s i had on the rear of my Z never rubbed. The second set rubbed on big dips and bumps - bad enough to the point where I had to roll the rear fenders.
Old Jan 11, 2013 | 04:41 PM
Spike100's Avatar
Spike100
Interesting... What sizes tires, and what size wheels and offset?
If I remember correctly, at some point you had 22mm offset on the rear with275's (I may be wrong).
--Spike
Old Jan 11, 2013 | 05:56 PM
DavesZ#3's Avatar
DavesZ#3
rear wheels are 19x10½ +22, tires are 285/35/19.
Old Jan 11, 2013 | 07:06 PM
Suwaidi's Avatar
Suwaidi
On a side note, go for Pilot Super Sports if they come in your size. Otherwise, PS2 would be the way to go in the Michelin line (as a second choice, PSS is a major improvement).
Old Jan 11, 2013 | 09:06 PM
JDMStanced's Avatar
JDMStanced
thanks for replies. i think im just going to buy new pair for the size im looking for.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
